Corinne Cleary
更新时间 2023-06-01 00:55:20 UTC
Please help.
浏览: 7893   回复: 1
Arturo Camin
更新时间 2023-05-30 09:17:10 UTC
浏览: 8003   回复: 1
Network Error with code: 3405
Stefan W.
更新时间 2023-05-27 20:05:45 UTC
Hi everyone. When I try to add another user in the app, I get the message „Network Error with code: 3405“
Any solution for this?
浏览: 8219   回复: 1
One channel is always on
Stefan W.
更新时间 2023-05-27 19:58:05 UTC
Hi everyone,
I have a 6-channel Sprite with 6 hunter valves. 5 channels work perfectly, one seems to be always on. I tried a brand new valve, a reset of the Sprite, unplugged it from power, changed the wiring but nothing helped. Any ideas?
Cheers, Stefan
浏览: 8038   回复: 3
Zones
Lea Schneider
更新时间 2023-05-25 23:29:01 UTC
My zones 5-12 won’t work but my zones 1-4 are working fine .    Any ideas what to do ?
浏览: 7894   回复: 1
Watering problem
Marco Nicosia
更新时间 2023-05-21 10:35:08 UTC
Does it happen to anyone that sometimes the irrigation starts by itself despite the program being set to manual?
浏览: 7632   回复: 1
更新时间 2023-05-14 12:23:35 UTC
Kirk
浏览: 8446   回复: 1
No light
Gabriele Gualtieri
更新时间 2023-05-10 17:13:50 UTC
浏览: 7842   回复: 1
Katie Woggins
更新时间 2023-04-24 18:40:07 UTC
浏览: 7669   回复: 1
Master error “open circuit”
Neil Lucey
更新时间 2023-04-24 14:09:12 UTC
Neil
浏览: 7774   回复: 1
Pixie keeps disconnecting
Sang Peiris
更新时间 2023-04-18 12:44:42 UTC
浏览: 7955   回复: 1
No 24V output?
Bigolin Davide
更新时间 2023-03-26 16:15:24 UTC
What can I do?
浏览: 7664   回复: 1
Carlo Drago
更新时间 2023-03-18 18:55:41 UTC
Waiting your kind reply
Carlo
浏览: 8124   回复: 1
Smart schedules
Vincent Coutinho
更新时间 2023-02-07 20:51:01 UTC
浏览: 8266   回复: 1
API
更新时间 2022-11-18 11:22:08 UTC
浏览: 8373   回复: 1
Gianluca Bus
更新时间 2022-11-03 12:03:59 UTC
Hi all!
Netro App vesion: 3.1.0
Netro controller hw ver.: 1.2
Thanks in advance.
Gianluca
浏览: 8039   回复: 1
Water valve opened
Paolo Talamelli
更新时间 2022-10-23 10:52:29 UTC
浏览: 7995   回复: 1
Sprite-6
Rockhead413
更新时间 2022-09-26 18:04:30 UTC
Vincent Devlahovich
浏览: 8336   回复: 1
Watering during a restriction
Valeria Dp
更新时间 2022-09-20 20:26:21 UTC
Tonight at 2.30 my netro start to watering. I had to stop it starting a manual program and stop it because in the app there was no watering sign.
Then I put a restriction for 3 days and around noon netro starts to watering again. There was a lost wifi signal for a minute cause by a voltage drop.
Is it normal?
浏览: 8225   回复: 1
Cannot reset Sprite
punyelroo
更新时间 2022-09-10 22:30:01 UTC
How do I fix this ?
-A
浏览: 8411   回复: 1
