Error E1
Simone Ragnolini
更新时间 2024-07-26 11:13:02 UTC
Ho, we need support, as we are having an issue as the app doesn’t activate watering. The control unot shows E1.
浏览: 7780   回复: 1
La zona non si spegne
Gmultis
更新时间 2024-07-17 16:29:38 UTC
Quando collego la valvola la zona resta alimentata a 24 v anche quando finisce il ciclo. Quindi non smette di irrigare anche con la spia di colore verde.
Senza la valvola invece la tensione torna 0 volt.
Cosa può essere il problema
浏览: 7945   回复: 2
Problem with irrigation time
Daniel Encinas
更新时间 2024-07-12 10:43:36 UTC
Hello, I have owned a Netro Sprite programmer for several years.
The problem I have is that it programs the phases intelligently and if it indicates that it has to water for 10 minutes. It only waters for about 1 minute but the app shows that it has watered for 10 minutes. The garden is drying out and I don't know what to do.
This happens to me in all irrigation phases. If I program it manually the same thing happens to me. If I try it twice, the second time it takes even less time to water.
I have connected the transformer directly to the phase, bypassing the programmer, and it works correctly.
Reviewing its problems section, I found a similar one in which it says to look at the 24 volt voltage. (which is correct, around 30 volt) and the resistance in ohms of more than 20 (around 30 ohmios). It also says that there the programmer has a recoverable fuse.
What can I do?
浏览: 7893   回复: 1
Cannot find master solenoid valve
kvschlegel
更新时间 2024-07-06 22:46:35 UTC
None of the zones are watering when the app says it's watering. I measured each zone when active and each read 28 AC. When testing the resistance, the readings were jumping all over the place for each reading. This is leading me to believe there is an issue with the master solenoid valve. However, there is no wire that connects to the M slot on the controller. Looking around the house for any of the underground boxes, I have not been able to find the master solenoid. Attaching pictures of what I have found. Any help greatly appreciated.
浏览: 8188   回复: 2
all connections good but sprite wont open any valves.
Douglas Ely
更新时间 2024-06-29 11:36:11 UTC
One day, the Sprite just stopped opening the zone valves. We tested and reconnected all the wires and deleted and re-installed the Sprite. Still no luck. Ground is good too. What could be wrong?
浏览: 8173   回复: 1
Netro Spark
Juan Manuel Fernández de Sosa
更新时间 2024-06-22 20:41:47 UTC
En relación con mi pregunta anterior ya he visto que poniendo el riego nocturno a las 23:30 se acepta, pero si se pone a las 23:59 sale el error. Por lo tanto anulen mi anterior pregunta, aunque me resulta algo extraño que no permita 23:59 siendo el mismo día.
Saludos.
浏览: 7713   回复: 1
Netro Spark
更新时间 2024-06-22 20:24:29 UTC
He instalado mi nuevo Netro Spark. En modo smart produce demasiados riegos en una determinada zona de forma muy constante, y con demasiado tiempo. No me parece nada lógico. Quiero dejar eliminado el modo smart y programar personalmente el riego. Consigo programar un riego de las cuatro zonas que utilizo en un determinado horario de la mañana, pero cuando voy a añadir un segundo riego diario por la noche me da un mensaje "ERROR: Program cannot cross a day".
¿Significa esto que solo puedo programar un riego al día? Muy extraño, mi anterior programador permitía tantos riegos diarios como quisiera simplemente indicando las horas.
Por favor, una solución, porque si solo se puede programar un riego al día no me soluciona nada este dispositivo.
Gracias.
浏览: 7974   回复: 1
one zone not opening
BBurford88
更新时间 2024-06-03 16:54:39 UTC
Has anyone had only one zone not work properly? I've checked my voltages and everything seems to be normal but one of my 4 zones does not operate either with the schedule or manually running the zone. Any tips help cause i'm at a complete loss.
Thanks in advance
Boyce
浏览: 7559   回复: 1
Pump shuts off after 5-10 mins
Vardhan Rajkumar
更新时间 2024-06-01 22:02:36 UTC
I just restarted my irrigation system after the winter.  I have tried to manually run a zone.  After watering for 5-10 mins the water turns off but the Netro timer still shows watering.
I am trying to determine whether the pump has turned off because the Netro "on" signal stopped or whether the thermal overload relay on the pump circuit caused it to shut off.
Is there a way I can check which it may be?
Vardhan
浏览: 7834   回复: 1
Multiple zones running on Netro Sprite sprinkler system
gosparty01
更新时间 2024-05-27 17:47:14 UTC
I have three zones that are running at the same time with low water pressure to all three. This is a new problem. Any ideas on hat might be causing it?
So far I've tried replacing one solenoid, that did not work. I switched the zones in the control box for one of the three zones but the same result when I activated the switched zone.
I also tried disconnecting one of the zones, and when I triggered it it did not run. But when I triggered one of the zones I left connected, it did run with low water pressure
浏览: 7697   回复: 1
Zone Won't Disable
更新时间 2024-05-25 20:49:25 UTC
I have tried to disable this zone in settings, but it will not disable.  If anyone knows a solutions please let me know.
浏览: 7912   回复: 1
Pixie Z1 Battery Drain
Passawit Kaovilai
更新时间 2024-05-12 03:01:25 UTC
One of my Pixie Z1 is after months of use is having abnormal battery drain where a 100% battery to dead within 3 days. Is this something warranty would cover?
I've replaced 3 sets of AA batteries now within a week or so.
浏览: 7686   回复: 1
Schedule issue
Barbara Williams
更新时间 2024-05-03 17:43:01 UTC
I have 3 zones. We have had system running for several weeks early in the morning. Yesterday I checked history & found all 3 zones had instead of a green checkmark icon, an orange wifi with red x icon (see photo below). I was able to try "run now", and only zone 1 worked.
I ended up deleting ALL schedules & did a one time water on zones 2 & 3 & they worked. I made a new schedule for all 3 zones, and this morning i got the orange wifi icon on zone 1, & zones 2 & 3 ran just fine.
Any ideas?   TIA!
浏览: 8024   回复: 1
ElctroValve don't sart
Francesco Merisio
更新时间 2024-05-02 20:19:07 UTC
Hy, i hava a problem.
When i start a irrigation cycle, only one Valve don't open, but when i start a test cycle from App, the same valve correctly open and start for few second the irrigation.
Why in the ccycke test the same valve it's ok and in the manually start don't go?
Idea?
grazie
浏览: 7940   回复: 1
Timer and sensor data incorrect on PC web browser
Mart B
更新时间 2024-04-21 17:25:05 UTC
I had to replace a dead timer a while ago, it and my whisperer are working great in my iPhone Netro app.
But ... when I log into my Netro home on a PC, using MS Edge web browser, my current equipment is not there, it has all my old stuff that should no longer exist ... I checked and am definitely logging in as the same account on both iOS and PC. It is very weird.
Is there any way to get this corrected?
浏览: 7785   回复: 1
Zone won't start watering
Homestead One
更新时间 2024-04-11 13:58:33 UTC
For some time one of my zones won't start watering. I have changed the valve with a new one but still won't start watering.
Any ideas? Thank you!
浏览: 7983   回复: 1
Open Circuit Master Valve
Matt Ward
更新时间 2024-04-08 23:44:05 UTC
My system is not working. When I run a valve test, it shows all valves are normal but the master valve has an open circuit error. I have checked all the wires and there is not voltage at the wires at the valve itself. I used a volt meter at the Netro controller and there is no voltage coming out of the controller for the master valve. Any suggestions?
Matt
浏览: 8363   回复: 1
weather scheduling
rafal72
更新时间 2024-04-02 21:10:48 UTC
Hi, Weather condition scheduling never worked and I've been using then Netro product for many years now. Currently both forecast & expectation are set at 0.1 threshold with skip (previous day, rainy day and next day). Weather station is set to NetroWeather and main app page is fairly accurate. Just today, it rained for most of the day and NetroWeather showed correctly "100% rain". Sadly, schedule program started anyway even though it was raining. I have changed weather provider, thresholds and nothing changes. This is very annoying to waste water, and I am looking for any tips how to mitigate this issue.
Cheers
Rafal
浏览: 7927   回复: 1
My sprite system battery
jeffrey fischer
更新时间 2024-02-18 16:39:36 UTC
My netro app give me a Notification "Device thirst quencher Low Battery"
I took the device apart and can see, what looks like, a small battery on the circuit board.  Does this need to be replaced?  And if so, where do I purchase a new one?
浏览: 7979   回复: 1
Spark showing error 1 on all solenoids
Mick Faulks
更新时间 2024-02-01 00:40:26 UTC
My Spark has stopped watering and is showing error 1 short circuit on every solenoid. I have tested each solenoid individually and they all operate disconnected from the spark. After multiple hard resets it started working correctly for a short time now it is saying all the solenoids are open circuit. I have tested all the solenoids and they are working perfectly.
浏览: 7987   回复: 2
