Roger Prunonosa Duran
更新时间 2021-11-22 10:30:32 UTC
They haven’t lasted much…
浏览: 9389   回复: 2
Yellow triangle error
James Mershon
更新时间 2021-10-06 12:23:33 UTC
浏览: 8120   回复: 1
更新时间 2021-10-03 16:59:12 UTC
浏览: 9145   回复: 1
Can't get our Netro to reset
Neil Hobbs
更新时间 2021-09-13 20:54:12 UTC
浏览: 8234   回复: 1
Power Supply
Jason Willis
更新时间 2021-09-12 12:27:04 UTC
Jason Willis
浏览: 8996   回复: 1
Connexio
Gerard Coulombe
更新时间 2021-09-12 11:02:25 UTC
Help needed
浏览: 8066   回复: 1
Program Not Running
Wally Carnes
更新时间 2021-09-09 02:37:52 UTC
浏览: 8954   回复: 2
Whisperer not working right.
vkanaga
更新时间 2021-08-27 23:46:35 UTC
浏览: 8670   回复: 1
Michael Gough
更新时间 2021-08-21 14:21:39 UTC
浏览: 8622   回复: 1
Daniel Encinas
更新时间 2021-08-18 06:17:45 UTC
Hi all,
Thanks a lot,
Daniel
浏览: 8390   回复: 1
Sensor doesn’t work correctly
Paolo Sciarappa
更新时间 2021-08-14 20:06:25 UTC
The graphic is very poor.
 Any suggestion.
Thanks Paolo
浏览: 8657   回复: 1
One zone not working
S Yarrish
更新时间 2021-08-06 00:50:19 UTC
浏览: 8255   回复: 1
更新时间 2021-07-26 16:02:28 UTC
浏览: 9001   回复: 2
Keep Online
bechard
更新时间 2021-07-24 11:09:25 UTC
浏览: 7754   回复: 0
gbs-122
更新时间 2021-07-11 10:22:07 UTC
浏览: 8439   回复: 2
Zero Readings
Billy Wood
更新时间 2021-06-26 00:28:05 UTC
浏览: 8579   回复: 1
Mike Willet
更新时间 2021-06-24 20:47:47 UTC
3 for backyard
3 for front yard
1 for drip irrigation in back
浏览: 8213   回复: 1
Reset whisper sensor
Yuriy Andamasov
更新时间 2021-06-24 18:06:20 UTC
Like hard reset
Not like that
浏览: 8681   回复: 1
Whisperer Bad Readings
Billy Wood
更新时间 2021-06-13 19:42:18 UTC
浏览: 8530   回复: 1
Low pressure on pixie
Martin Le Ménach
更新时间 2021-06-08 07:20:16 UTC
浏览: 8384   回复: 1
