Yohan
更新时间 2020-03-22 00:49:00 UTC
浏览: 9179   回复: 1
stefano banfi gaslini
更新时间 2020-03-18 15:16:20 UTC
hi,
it was particularly dry.
indicates that it is 98% wet.
what is wrong?
tnks
best regards
stefano
浏览: 8987   回复: 1
Whisperer issue
Saul Perez
更新时间 2020-03-15 19:07:50 UTC
浏览: 8691   回复: 1
Benedetto
更新时间 2020-03-11 14:44:38 UTC
Thanks for the support
Br
BG
浏览: 9070   回复: 1
Watering stops after 5 mins
D String
更新时间 2020-02-29 17:22:32 UTC
浏览: 8558   回复: 1
Watering stop problem
lekter
更新时间 2020-02-14 14:43:36 UTC
When I start watering to give it a try. Everything's going well. But when I want to stop watering it's impossible. I have to turn off the power so that netro stops the watering.
WeatherPro is the problem ?
For information, I have an electrovanne rainbird.
Arnaud
浏览: 9019   回复: 0
Light still blinking fast after pressing RST button
marcplesh
更新时间 2020-01-20 23:27:20 UTC
Any suggestions? Thanks. Already unplugged from outlet for about 10 seconds and plugged back in.
浏览: 8932   回复: 1
setting up sprite location service on cellphone not on ... but it is
Michael Pakalolo
更新时间 2020-01-12 16:51:03 UTC
hi there, my sprite was working fine for 3 month , now i had no internet for 24 hours and sprite did not connect to the internet anymore . I restarted the router and then the sprite and still no internet connection but my router is fine and i have internet. So i reset the sprite and now it says i need to allow location service on my phone but it is on!!! it will not allow me to setup the sprite and i don't know what to do?
浏览: 9299   回复: 1
Tim Foster
更新时间 2019-12-05 17:56:44 UTC
浏览: 9381   回复: 1
Brian Hobbs
更新时间 2019-10-15 01:58:49 UTC
浏览: 9228   回复: 1
Nguyễn Vinh
更新时间 2019-09-30 06:46:55 UTC
浏览: 9731   回复: 2
更新时间 2019-09-17 12:12:15 UTC
浏览: 9727   回复: 1
Power Transformer
DeanH
更新时间 2019-09-04 02:31:34 UTC
I have my controller in my garage here in the desert.  The transformer seems very hot to the touch.  Is this a problem??
浏览: 10918   回复: 3
Yellow triangle with ! Inside
Michael Pakalolo
更新时间 2019-08-24 16:15:54 UTC
What does the yellow triangle with the ! mean next to the schedule
浏览: 9354   回复: 1
Zones run at the same time
Rich Christenson
更新时间 2019-08-15 11:05:09 UTC
浏览: 9921   回复: 3
Low pressure in zones
Hussein Diab
更新时间 2019-07-29 16:36:31 UTC
浏览: 9067   回复: 1
Water stops running before the cycle is over
sgschrank
更新时间 2019-07-18 18:03:03 UTC
Recently I have been having issues with zones 5-8 stop watering before the cycle is over, but keeps counting down and moves to the next zone and does the same thing. I have tried resetting the unit, re-linking the wifi, but doesn't seem to make a difference. Help!
浏览: 9039   回复: 0
更新时间 2019-07-12 15:05:29 UTC
浏览: 10290   回复: 1
Rod Timby
更新时间 2019-07-11 18:14:39 UTC
浏览: 9086   回复: 1
Rod Timby
更新时间 2019-07-11 18:09:47 UTC
浏览: 8919   回复: 0
