Wi-Fi connectivity
saketshah
更新时间 2021-05-31 21:20:22 UTC
Appreciate your help.
浏览: 8219   回复: 1
Wisperer not working
Andrea Paparotti
更新时间 2021-05-31 14:42:20 UTC
浏览: 9111   回复: 2
Netro Pixie Timer
claudinne
更新时间 2021-05-20 17:09:36 UTC
浏览: 8299   回复: 1
Whisperer shows different data on hourly vs daily humidity
Panos Charalambopoulos
更新时间 2021-05-03 07:40:53 UTC
My whisperer shows 99% humidity stuck in one zone in the hourly and dashboard views. The weekly daily monthly views all show progressively dropping humidity. Which one is correct and how do I possibly reset this ? Also do my watering schedules get affected by the hourly or the daily humidity ?  My other whisperer shows consistent data between hourly and other views.
浏览: 8201   回复: 1
Whisper controlled zone down to 11%
Simon Clark
更新时间 2021-04-28 20:59:55 UTC
I have a whisper connected to a zone that I have defined as new plant as it’s young vegetable plants. It says it will run every day for 9 minutes.
However it’s not come on for the last week and when I checked today the moisture was down to 11%!
Why hasn’t the zone been running?
I can’t rely on your product if it doesn’t do the basics that keeps my plants alive.
浏览: 8718   回复: 1
Weather data
Vardhan Rajkumar
更新时间 2021-04-21 18:03:34 UTC
Vardhan
浏览: 8791   回复: 1
Michael Sheahan
更新时间 2021-04-19 21:19:54 UTC
浏览: 8147   回复: 1
Tony Pellegrino
更新时间 2021-04-13 19:14:36 UTC
浏览: 8262   回复: 1
jjmengibar
更新时间 2021-04-05 18:19:11 UTC
浏览: 8965   回复: 1
Many inexplicable Manual runs
更新时间 2021-04-03 11:37:15 UTC
Hello everyone ,
浏览: 8363   回复: 1
Wild Swings In Moisture %
Mike Biondo
更新时间 2021-03-27 22:08:54 UTC
I am seeing 20%+ increases in soil moisture when there is no rain and I am not watering and also 20%+ reductions in moisture directly after watering which seems counterintuitive. Is this normal? Can anyone explain what is going on to me? Thank you!
Mike
浏览: 8725   回复: 1
AMC
更新时间 2021-02-18 13:04:06 UTC
hello,
¿How Can I solve this issue?
APP version 2.5.3
浏览: 8768   回复: 3
Master valve timing
joeac
更新时间 2020-12-04 05:38:31 UTC
Product: Sprite
Joe
浏览: 8506   回复: 1
Email address length
Alberto Castro Hinojosa
更新时间 2020-10-24 21:37:57 UTC
Could you review please?
浏览: 8532   回复: 1
HomeOwner
Isaac Fishman
更新时间 2020-09-21 01:14:55 UTC
浏览: 8312   回复: 1
controller kept go offline
更新时间 2020-09-05 01:12:13 UTC
Hello, wondering why my watering controller kept going offline.  Once turning it off/on, it will goes online again but will go off in several hours later.  Is it time for me to get a new controller?  I hope not
浏览: 9554   回复: 2
Battery not charging
Petar Nedyalkov
更新时间 2020-08-21 18:24:41 UTC
My solar powered controller doesn’t charge its battery - not sure if it’s a battery problem - the controller is under direct sunlight for at least 6 hours every day.
I’ve set it to water for 1 hour every day so it’s a simple On/Off once a day.
Have other people had this issue?
浏览: 9284   回复: 2
Unable to reset into Host mode to change WiFi setting
dabo
更新时间 2020-08-16 17:29:54 UTC
I have a 6 zone Netro sprite and need to update my wifi settings. No matter what I do I'm unable to get the Netro to enter host mode. I've tried hitting the RST button numerous times before or after manual reboots (even waiting the full 3+ minutes after re-plugging the device in). I even tried a full manual reset by holding the RST button for 10 seconds and the device still doesn't reset. I'm starting to doubt whether the reset button on my device works.
Has any one had any similar problems or pointers for just getting the Netro to join a new WiFi network? I'd rather not do a full reset and lose my zone settings, but at this point I've even tried that and can't get that working.
浏览: 8831   回复: 2
No funciona
Fre Camp
更新时间 2020-08-13 07:40:48 UTC
En la APP todo parece ir bien, pero no riega.
浏览: 8708   回复: 2
Battery not holding charge
Steve Walczak
更新时间 2020-08-12 17:49:20 UTC
浏览: 8595   回复: 2
