Clicking off before scheduled time
paul hewitt
更新时间 2023-11-24 01:07:07 UTC
This morning my retic was coming on the usual schedule but I noticed that it seemed to only be on for a few minutes instead of the set 30 mins.
The system said it was watering but it had turned off. I set a station manually for 10 minutes and after approx 4.5 mins it clicked off at the controller but the app said it was still running. I tried another station and it has the same issue ie it is set to run for 30 mins but clicks off after 4.5 mins but the app says it is still watering. I then waited for the next scheduled station to turn on at 8.50am and it clicked on as usual but after approx 5 mins it clicked off but app said it is still running.
I reinstalled the app and that didn't work so then did a hard reset but I still have the same problem.
I can't figure out why the controller is clicking off but the app says it is still watering.
Any ideas?
Paul
浏览: 8448   回复: 1
Zone failure to run
Homestead One
更新时间 2023-10-09 08:30:37 UTC
Hi, I have one out of 4 zones who won't start watering. I have changed the valve and the problem still persist. I have checked the connections and the cables, all looks good. There is voltage.
Any ideea?
浏览: 7438   回复: 1
Zone Failure
Ben Pittarelli
更新时间 2023-10-03 12:31:07 UTC
I have the Sprite 12 controller with zone 3 failing to work after 10 months.  Traced error to low voltage on controller. Anyone else having zone failures caused by controller?
Moved wire to unused zone 12 and sprinklers engage as they should.
浏览: 8245   回复: 1
Whisperer 2 "serial already in used" issue
pridebowl33
更新时间 2023-09-29 16:07:36 UTC
I have been trying to add back one of my Whisperer 2 sensor and got a message saying that the serial has been already in used. Not sure what to do at this point. I was wondering if someone had encountered the same issue and if there is a solution to fix it.
Kevin
浏览: 8181   回复: 1
Unrequested watering cycle
Claudio Polacco
更新时间 2023-09-23 07:00:27 UTC
Hello everybody, maybe someone can help.
This morning I found the irrigation system on, watering the garden, with no schedule active. More, the master enable/disable switch on the app homepage was set to off.
I'm using manual zone scheduling, not smart watering.
The controller is a Netro Sprite 6 zones, Wifi was on and fully functional.
Any ideas? Thanks.
Claudio
浏览: 8253   回复: 1
Jacob Matheny
更新时间 2023-09-01 13:44:37 UTC
浏览: 8680   回复: 1
Leandro
更新时间 2023-08-31 10:48:12 UTC
HI Support Team and All,
This wasn't written anywhere.
thank you all
Leandro
浏览: 8138   回复: 2
Scott Yates
更新时间 2023-08-29 12:38:49 UTC
浏览: 8531   回复: 1
Pixie
Charles Schatz
更新时间 2023-08-12 15:53:10 UTC
How do I synch my pixie without having to wait for the scheduled time?
浏览: 7929   回复: 1
Netro Sprite 6 valve won’t stop
Alberto Casu
更新时间 2023-07-29 19:25:45 UTC
I just replaced my sprinkler controller with a new Netro Sprite 6.
Using both a programmed or a manual start, all valves don’t stop unless I remove power to the Sprite.
During a program, where I planned the zones to run sequentially, the zones activate one after the other without stopping and causing the zones to loose pressure and be unable to complete.
On the FAQ, it says to remove power to stop the zone, which actually stop all the watering, but this it totally unusable to me.
I am using the European version with the provided power supplier. I am based in Italy.
Can you please help?
浏览: 8585   回复: 2
Netro - Stopped Working and won’t power up
John Loethen
更新时间 2023-07-25 14:04:38 UTC
Been a Netro customer for a while and pretty handy. I have three different Netro controllers and my oldest one just stopped working and won’t power up… I have verified the power at the outlet and have changed out the power supply with another 24v power supply that I know works. Still the controller will not power up.
Let me know if anyone else has suggestions.
John in Lincoln, NE
浏览: 8007   回复: 1
misterhoff
更新时间 2023-07-25 03:11:25 UTC
浏览: 7805   回复: 0
更新时间 2023-07-24 00:54:03 UTC
浏览: 8620   回复: 1
Can't reconnect wifi
Yuriy Andamasov
更新时间 2023-07-05 21:14:40 UTC
sprite-6 went offline
never pass step 5
worked just fine almost year
浏览: 8235   回复: 1
Battery LED Blinking
E B
更新时间 2023-06-29 15:33:28 UTC
浏览: 8748   回复: 1
Connection issue
Federica Musmanno
更新时间 2023-06-27 12:16:35 UTC
浏览: 7906   回复: 1
Massimo Oldrini
更新时间 2023-06-20 07:57:16 UTC
Buongiorno,
L’apparato va sostituito?
浏览: 7915   回复: 2
Whisperer sensor
更新时间 2023-06-10 17:39:10 UTC
浏览: 8720   回复: 1
Netro sprite chpset.
Eduardo Pariente
更新时间 2023-06-09 18:15:34 UTC
Hello everyone.
Thanks you.
浏览: 7899   回复: 0
Eduardo Pariente
更新时间 2023-06-09 18:15:24 UTC
Hello everyone.
Thanks you.
浏览: 7999   回复: 1
