How to Increase Battery Charging
antwan
更新时间 2026-10-10 01:44:08 UTC
My Pixie has been offline since last spring. When I restablished the connection it showed only 17% chargers the anyway to supplement the solar charging to increase the charge?
浏览: 603   回复: 0
Internet reconnection issue
Gianluca T
更新时间 2026-09-17 19:39:14 UTC
hi,
everytime the power goes off and come back on, the wifi router take longer than the netro sprite to restart. it looks like netro try to connect to the internet just once (or at least only before the router is back online). the result is that every time the power goes off and come back on netro sprite can't connect to the internet and i have to manually switch it off and on after the router is back online. This is becoming a big issue, is there a patch to this? the Netro Sprite needs to try to connect again and again at least every hour. better if every 10 minutes.
please let me known.
best regards
浏览: 938   回复: 1
Offline and “connecting”
Miguel Camarillo
更新时间 2026-08-29 14:11:05 UTC
My netro sprite shows a green light on but remains offline in the app. When I try and run a sprinkler it shows “connecting” and the sprinkler never comes on. I’ve tried unplugging it, resetting, and ensured everything is properly wired. My internet connection is also strong and stable. It has worked perfectly for the past 6 months until now. I purchased it in February of this year.
Please help I’m out of ideas.
浏览: 1281   回复: 0
Shut off at 2 mn
jsolis
更新时间 2026-08-26 22:17:56 UTC
Each zone started shutting off after 2mn when doing a manual run. The system has been working for 3 yrs.
浏览: 1269   回复: 0
Shut off at 2 mn
jsolis
更新时间 2026-08-26 22:17:41 UTC
浏览: 1324   回复: 1
Candice Wang
更新时间 2026-08-06 07:50:00 UTC
Dear Netro Community,
What We Are Doing
📧 support@netrohome.com
Best regards,
Netro Support Team
浏览: 9334   评论: 0
sprite not using correct weather data
Douglas Peale
更新时间 2026-05-26 06:47:02 UTC
I have a home weather station that feeds data to https://www.wunderground.com/dashboard/pws/KCASANJO507?cm_ven=localwx_pwsdash
I have my sprite pointed at my specific weather station on wundergound.com. Today, my sprite claims I had 0.02" of rain, but my weather station detected none, and wunderground.com says I had no rain.
I have been noticing for a while that Netro was showing different rain data from what my weather station recorded, Netro usually records more rain than I actually got. I suspect this may be why my oranges are always under sized.
Somehow Netro is getting the wrong infromation from wunderground.com. Is there any way to fix this?
浏览: 2211   回复: 1
Zones not running
Richard Snyder
更新时间 2026-05-14 13:48:46 UTC
All zones are programmed to run but only zone 1 runs.
浏览: 2249   回复: 2
Will
更新时间 2026-01-27 03:13:26 UTC
浏览: 3393   回复: 1
Old whisperer
更新时间 2026-01-20 10:38:33 UTC
Seems a communication problem
浏览: 3351   回复: 1
The average temperature for a day is insufficient to calculate correct watering.
Richard
更新时间 2025-12-17 07:17:57 UTC
When I have Whisperers, the system appears to calculate the average over the day about 4 degrees higher than for zones without Whisperers.
It seems that, even though the weather data is available throughout the day, that zones without sensors only use the forecast high and low.
This is insufficient to correctly adjust for the amount of watering required.
For example, today is 7 degrees C up to 36.
Whisperer zones average the temp at 26C while non-Whisperer zone calculate the average at 22C.
On these extremely hot days, the non-whisperer zones are under-watering much more than the Whisperer zones.
Also note that even the zones with Whisperers always under-water and needs custom programs or manual intervention.
This finally explains to me why zones are always under-watered.
Can the system please use multiple day readings for non-Whisperer zones and PLEASE provide more watering?
浏览: 3670   回复: 2
No water comes out when I started my Netro
Fay Hatfield
更新时间 2025-11-09 20:53:57 UTC
Hi everyone, I purchased my Netro about one year and half ago. It used to work normally. It stop working a couple months ago. When I started it, it says watering but no actual water comes out. I did everything the support team told me to do but still nothing happened. I’m desperate, my grass is dying. Someone please assist.
浏览: 4546   评论: 3
Problem: Spark 16 controller stuck on "in communication"
Corrado
更新时间 2025-10-08 13:48:10 UTC
I'm experiencing a serious issue with my Netro Spark 16 controller. It connects correctly to Wi-Fi and appears online in the app, but when I try to start irrigation manually, the app just stays on "in communication" and nothing happens.
The problemm is with the 4g Vodafone/HoMobile provider as yout mentioned in https://netrohome.com/en/forum/posts/4052
I have already asked several time the update for the device, but nobody reply me
i wrote also to Netro support email: support@netrohome.com  --> nobody reply me.
What should i do to have this update?
Please
浏览: 4064   回复: 1
Remote reboot of whisperer
更新时间 2025-08-17 14:48:38 UTC
Is there a way to remotely reboot a whisperer sensor?
I am on vacation adn one of the sensors is showing up weird values in all the parameters.
浏览: 6751   回复: 1
Whisper not showing any moisture reading at all
更新时间 2025-08-12 02:45:00 UTC
Why is Whisperer not showing any moisture reading at all? after working fine for days, it just stops sending moisture info
浏览: 6916   回复: 1
Problem: Spark 8 controller stuck on "in communication"
Stefano F
更新时间 2025-08-10 07:01:41 UTC
Hi everyone,
I'm experiencing a serious issue with my Netro Spark 8 controller. It connects correctly to Wi-Fi and appears online in the app, but when I try to start irrigation manually, the app just stays on "in communication" and nothing happens.
Despite these attempts, the problem persists. I also tested the solenoids with a multimeter, and they’re working correctly. If I activate the valves directly from the controller, they respond as expected—so it’s clearly not a hardware issue.
I should also mention that I previously had the same problem with two Sprite6 controllers. That’s why I switched to the Spark 8, hoping it would solve the issue. Unfortunately, it hasn’t.
To make matters worse, scheduled programs aren’t working either.
This is an urgent situation because my plants are currently without water. I’d really appreciate any help or suggestions to resolve this.
Thanks in advance,
Stefano
浏览: 4477   回复: 2
Daniele Fuccio
更新时间 2025-07-18 17:17:18 UTC
What could the issue be?
Thank you in advance
浏览: 5093   回复: 1
Ricardo Ribeiro
更新时间 2025-07-12 13:05:48 UTC
Can you help?
浏览: 5105   回复: 1
Umidità terreno
Alessandro Zannini
更新时间 2025-07-03 19:20:15 UTC
浏览: 7694   回复: 1
Whisperer 1 Dead
更新时间 2025-07-03 15:13:13 UTC
浏览: 7512   回复: 0
