Whisper 2 88% to 34% in 30 mins?
更新时间 2026-09-01 12:43:37 UTC
I have a zone that keeps overwatering. It has erratic shifts in water percentage, usually occurring after the zone is watered. This results in the zone then coming back on again and running for an extremely long period of time (extra water cycle). I would hate to think that the sensor is bad again, as I’ve had this one replaced twice in the last year. I tried moving the location of it, of course, tried resetting the learning on it, but it is a recurrent situation.
Also kind of goofy we cannot attach photos…
浏览: 1443   回复: 0
Smart watering isn’t working
Weikang Chen
更新时间 2026-08-21 00:17:31 UTC
I have 2 problems with the Netro this year.
1. The weather auto detect to rain to skip the water session doesn’t work.   No matter how low the threshold I set to, it doesn’t skip the water day when it rains.  I have it set to .1 inch now.
2. When I set to delay the watering , it doesn’t reschedule the schedule.   It just continue with the watering.
My system has been watering while it’s pouring outside so many times and wasted so much money on my water bill because this app screwed up so bad.
Is there a the fix to my problems?
浏览: 1651   回复: 1
Whisperer 2
Joan Garrell
更新时间 2026-08-13 09:03:11 UTC
浏览: 2133   回复: 1
Purchasing a moisture sensor
Gyade B.
更新时间 2026-08-09 15:34:55 UTC
How do I purchase a Netro Controller moisture sensor?
浏览: 2257   回复: 1
更新时间 2026-08-06 07:50:00 UTC
Dear Netro Community,
What We Are Doing
📧 support@netrohome.com
Best regards,
Netro Support Team
浏览: 10031   评论: 0
Pixie and smart water sensor
Thomas Lamb
更新时间 2026-07-26 12:29:27 UTC
Is there any way to use the smart plant sensor gen 2 with my pixie?
浏览: 1887   回复: 1
Pixie and Amazon drop irrigation
Thomas Lamb
更新时间 2026-07-26 12:25:28 UTC
I added a pixie to my system and hooked it up to a drop irrigation system from Amazon. My deck plants survived my summer vacation away from them.
浏览: 1917   评论: 1
Netro Smart Settings
caravagg
更新时间 2026-06-30 11:58:32 UTC
netro smart settings, please rank relative seasonal water use from high to low for the different settings: EPA, Boost, New Plant, Deep, Frequent, Regular, ECO
浏览: 2110   回复: 1
How does eco factor work?
更新时间 2026-06-21 16:02:22 UTC
浏览: 2215   回复: 1
Can you add rain sensor to the Spark system? Is there one available?
Devros
更新时间 2026-06-12 00:03:03 UTC
Just wondering if you can add a rain sensor to the Spark system?  If so what brand?
浏览: 2362   回复: 1
Rain forecast
Riccardo!!
更新时间 2026-05-31 15:34:34 UTC
Hi, I have a Spark controller. Where can I find in the app the rainfall forecast for next days?
In the home page I can see only humidity, temperature and wind but not rain in mm.
Riccardo
浏览: 2304   回复: 1
wunderground
Nino Guzzo
更新时间 2026-05-28 17:35:15 UTC
I can't register my weather station ID in the Netro app. Can anyone help me? Thanks.
浏览: 2530   回复: 1
Longer watering per zone
Ruud
更新时间 2026-05-16 21:17:27 UTC
I have a Netro Sprite (6 zones).
I would like to water one time a week, 4 hours per zone in one run. I am not able to make programmes and single runs longer than 60 minutes.
Am I doing something wrong, or is this not supported?
Thanks for helping me out.
浏览: 2461   回复: 2
Sensores fallan
Juan Pascual
更新时间 2026-05-12 13:01:26 UTC
Todos los sensores que he adquirido al cabo de dos años dejan de cargarse por el panel solar y son inservibles
Conectados por usb a una fuente de alimentación son capaz de emparejarse pero al desconectarse dejan de funcionar
Enchufados a la corriente la luz única un bucle de rojo de menos a más parpadeo amarillo y parpadeo verde. Los puedo dejar cargando por usb 12 horas pero al desconectarlo se mueren
Alguna solución ?
浏览: 2498   回复: 1
Feature Request / Setup Assistance: Apply Rain Skip to User Programs without Smart Scheduling
Alessandro Zannini
更新时间 2026-05-01 16:47:43 UTC
Hello Netro Support Team,
I am a user of the Netro system and I need assistance with my zone configuration.
Currently, I have a specific zone (named "Goccia") set up with a User Program (fixed days and fixed minutes). I do not want the Netro AI to change my watering duration or frequency.
However, I want the system to automatically skip my fixed program if it rains or if rain is predicted.
In my app settings for this zone, I see that "Smart Zone" is currently Disabled. My questions are:
1. If I enable "Smart Zone", will it overwrite my manual minutes and days, or will it only apply the "Rain Skip" feature to my existing User Program?
2. How can I ensure that the system follows my fixed schedule strictly, but still uses weather data to skip cycles during rain?
I want my manual program to be "Weather-aware" without becoming "AI-controlled".
Thank you for your help.
Best regards,
浏览: 2584   回复: 1
Different weather and does not skip rainy days
Leonardo A
更新时间 2026-04-20 06:25:01 UTC
Good morning, if anyone can help me, I have two Netro control units installed 1 km from each other and they give me two different forecasts, both having the same weather portal, one irrigates it even with rainy days, while the other gives me the programming in 20 days.....
浏览: 3597   回复: 1
Not skipping raining days
Felipe VNunes
更新时间 2026-04-17 23:00:44 UTC
Hi guys,
My Netro system is not skipping watering on rainy days. As shown below, it still watered even though it is configured to skip the previous day, the rainy day itself, and the day after. Any recommendations?
浏览: 3131   回复: 1
Support email- No reply
更新时间 2026-02-21 16:06:19 UTC
浏览: 3761   回复: 2
cpline
更新时间 2026-02-02 17:04:38 UTC
浏览: 3611   回复: 1
Watering on wrong day
keller3987
更新时间 2025-12-09 15:39:44 UTC
I have programmed my Netro to skip Tuesday’s but the controller waters anyway. How do I stop this?
浏览: 3847   回复: 1
