Stop manual mode
Martina Brasesco
更新时间 2024-02-04 15:19:31 UTC
Buongiorno,
ho appena installato il mio nuovo NETRO, ma non riesco a stoppare l'irrigazione che è partita automaticamente non appena lo ho installato. Potreste aiutarmi?
浏览: 8327   回复: 1
Moisture watering adjustment
更新时间 2024-01-09 20:27:04 UTC
Hi there I have one of the whisperer that doesn't allow to adjust watering below 50%,
Sensor number 2 in my installation.
All the rest I can chose lower values
浏览: 8697   回复: 1
Richard
更新时间 2024-01-07 22:48:08 UTC
UPDATE 8/1/2024
UPDATE: 5/1/2024
UPDATE: 4/1/2024
ORIGINAL:
浏览: 10343   评论: 11
PM time
Cacho
更新时间 2023-12-31 19:38:05 UTC
Hello, need help.
I cannot enter PM times on program.
Always return to AM. Not possible program at night.
浏览: 7968   回复: 0
Whisperer maintenance
Fabrice GOUFFRAN
更新时间 2023-10-11 02:34:36 UTC
浏览: 7144   回复: 1
Yellow exclamation mark
MyGowdy
更新时间 2023-10-07 23:05:24 UTC
浏览: 8415   回复: 1
Phil Middleton
更新时间 2023-09-30 12:48:53 UTC
Kind regards
Phil
浏览: 8801   回复: 1
kamiller42
更新时间 2023-09-29 15:44:58 UTC
浏览: 8161   回复: 1
David Solis
更新时间 2023-09-14 21:05:39 UTC
Thank you in advance
David
浏览: 8752   回复: 2
smart zone advanced range
Leandro
更新时间 2023-09-12 17:37:36 UTC
Thanks for the reply
Leandro
浏览: 8266   回复: 1
Soil moisture adjustment
更新时间 2023-09-12 01:34:23 UTC
浏览: 8908   回复: 1
Irrigreen sprinklers
更新时间 2023-09-09 08:34:33 UTC
Combining with the whisperers
https://irrigreen.com/
浏览: 9335   评论: 0
Parallel Run of watering
C He
更新时间 2023-09-08 08:39:13 UTC
Hallo and short question:
浏览: 8829   回复: 2
C He
更新时间 2023-09-04 06:22:44 UTC
This is smart watering?
浏览: 8668   回复: 1
C He
更新时间 2023-08-17 05:23:52 UTC
Hello Netro Support,
What’s wrong?
浏览: 8463   回复: 2
Moisture to skip watering
Maurizio Gianesin
更新时间 2023-08-15 19:55:07 UTC
I appreciate any answer .
Many thanks
浏览: 8134   回复: 1
Calendar View
更新时间 2023-08-10 11:23:26 UTC
Netro Support Team,
Houston, Texas
浏览: 8554   回复: 1
We had 4 inches of rain
更新时间 2023-08-09 03:08:18 UTC
浏览: 8705   回复: 2
Atif Siddiqui
更新时间 2023-08-02 04:51:58 UTC
浏览: 8142   回复: 1
Mirko Zen
更新时间 2023-07-21 09:35:33 UTC
浏览: 8026   回复: 1
