1 zone not watering
cowlo@xtra.co.nz
更新时间 2024-10-01 01:41:13 UTC
浏览: 9102   回复: 1
Pierluigi Cilli
更新时间 2024-09-08 07:29:59 UTC
浏览: 8915   回复: 1
Can't get desired watering time
Fabio Silvestri
更新时间 2024-07-24 19:24:30 UTC
I'm struggling to setup watering time, even after third season im using this app.
As per my settings, EPA suggest to water every day, 30 minutes a day for each zone. The grass is getting sick as all past 2 years, cause the frequency is too high.
I would expect it to water for 1 hour, each 3-4 days. This is what i call "deep watering".
I tried following settings, the frequency decreases, but no way that i can increase the watering time which remains 30 minutes.
Help please
浏览: 9286   回复: 1
Connection
jackielaith
更新时间 2024-07-21 04:36:32 UTC
Can't connect to the internet with this app
浏览: 8948   回复: 1
Bug in Smart watering Algorithm
texan4ever521
更新时间 2024-07-16 18:53:40 UTC
I would like to know how to get a serious bug in the smart watering algorithm resolved.
I live in north Dallas.  All of our soil is clay.  Most yards (like mine) have Bermuda grass, which is extremely drought tolerant.  This grass grows roots several feet deep and can survive with zero watering for 3 weeks after a downpour that saturates the clay.  (I can show you green grass in a yard that is hard as a rock)  During mid July to mid September the average low is 80 and the high is over 100.  Bermuda grass will go dormant(not dead) if not watered during summer.  You can easily keep the yard looking decent with only 10 minutes of watering per week.
I bought my house in 2020 and it came with a Netro.  After a summer of use, my wife and I failed to look at the auto-pay CC card water bills.  We had accidently spent thousands of dollars on yard watering during the summer. (I can show the water bills)!  (FYI, I had each zone set to the max ECO level)  Instead of buying a new timer, I changed smart-zone to basic instead of advanced and setup very detailed schedules.
My timer got hit by lightning back in May.  I bought a new one and set it up.  I failed to notice that the default value for new zones is "smart zone enabled with advanced setting".  Even though I had set up manual programs the timer found 'loop holes'.  The advanced mode was watering some zones as much as 70 minutes in 1 WEEK!  (compared to previous 10 min a week).  My water bill went from $160 to $400 ( at least I caught it before it got to $800 again).
This bug has literally cost me thousands of dollars with a feature that is supposed to be saving me money.  I am not asking for compensation, it was my mistake that that I failed to look at the schedule and CC auto-pay.
But this bug is ridiculous.
How do we get the following implemented:
1) Global setting for water conservation (impacts all zones) that limits the max per week and max per month that a zone can be watered
2) Budgets inside manual programs that will set limits for max per week and max per month.
3) expand frequency for programs to be across 14 days instead of 7 days
4) notifications from app that informs owner of minutes watered per week and per month.
浏览: 8030   回复: 0
2 zones must run the same amount of time
更新时间 2024-07-06 15:35:53 UTC
Hi there
I have the garden zones like the diagram. And I want zone 4 a 3 run the same amount of time. Currently they use different whisperers and have different schedules what makes the grass to present in summer dry patches. I would like to force to run 3 and 4 the same amount of time.
Should I use only one whisperer attached to both zones (3 and 4)?
浏览: 8823   回复: 3
Netro sprite-6 with power adapter 600 ma?
Nuno Fs
更新时间 2024-06-28 12:33:25 UTC
Just bought a Netro sprite-6 and a power adapter 600 ma but the sprinklers go up but not down, why? Could it be the amperage?
I exchange the power adapter for a 800 mA and i still have the same problem.
If i do a manual irrigation and turn  it off in the middle it doesnt turn off,but if i tried once more to turn it on it turns it off....
Nuno
浏览: 7947   回复: 1
programs overlaping (smart scheduler and watering adjustment)
更新时间 2024-06-25 10:19:26 UTC
The smart schedule overlaps with the watering adjustment program that runs when the moisture goes below a %.
Yo can see here that zone 5 run 10 minutes the program and then 37 minutes the scheduler.  It has no sense and it is a waste of water.
  1. After the watering adjustment run, the smart scheduler should recalibrate the timing based on the humidity of the land.
  2. I have the whisperers, the whisperer should monitor the humidity and stop the smart watering once it reaches 99% of humidity but it seems the program runs all the way.
This could be improved in the application.
Thanks for your support and keep up the good job
浏览: 8603   回复: 1
Need a notification, other than in calendar, when watering doesn't work.
Jake Tanner
更新时间 2024-06-16 22:53:34 UTC
Apparently there are times when the wifi connection to one of our Pixie devices is not reliable.  Yes, I should work on that.  However, it has worked flawlessly in the past, and this is something new.  Nonetheless, when the water schedule fails because of no wifi signal, there should be some kind of notifcation OTHER than having to open the app, go to the calendar, and look for the tiny red icon.  The app is right there on the phone, and could generate a notification.  The app has the email address and could generate a notification.  The current method is borderline dysfunctional, and mostly useless.
The main screen can say "Watered 10 hours ago"  .. but the calendar OBVIOUSLY shows that that even did not happen.
浏览: 7901   回复: 1
Rain skip only
Shawn C
更新时间 2024-06-02 21:09:04 UTC
How do I setup the Netro to only check for rain and skip the rainy days ?  I don’t want it to enable smart watering and change my watering schedule but I would like it to detect and skip rainy days.  Thanks!
浏览: 8214   回复: 1
SMART WATERING MODES
Javier NM
更新时间 2024-05-12 06:32:07 UTC
Is there an article explaining the different watering modes of smart watering, more that the one line info on the menu? I am looking at information like levels of humidity pursued, depth of watering, or circumstances under which each mode is recommended.  Thank you
浏览: 8419   回复: 1
Wafering even when raining
Fabio Silvestri
更新时间 2024-05-07 19:59:22 UTC
I don't understand the logic behind watering after training. Yesterday and today we had heavy Rain, but the Smart schedule plans to start in 9 hours. In the app I also set to stop watering the day before and after Rain, but that seems to have no effect. Temperatures are low as well, i wouldn't expect watering to start before at least 10 days.
浏览: 8496   回复: 1
Whisperer 2 problems
Bruno
更新时间 2024-04-17 20:54:19 UTC
As you can see the humidity sensor give some strange readings...
How can change those values in such way without touching the sensor or watering. I'm scared of the reliability of such things...
浏览: 8697   回复: 1
Skip watering did not work
更新时间 2024-04-17 12:50:29 UTC
I have the whisperer to avoid watering over 40% humidity, but the system did not skip it
浏览: 8371   回复: 1
Water time
Wil
更新时间 2024-04-17 04:36:26 UTC
How can I get this to water a certain time.  Like my gardens at 6am?
浏览: 7966   回复: 0
Waters too much
Wil
更新时间 2024-04-17 04:34:42 UTC
I inputted my own program. I want it to water the durations I entered.  It doesn't.  How can I turn the so called smart feature off?
浏览: 8275   回复: 1
Zone 1 watering everyday
antonio.manso@gmail.com
更新时间 2024-04-13 05:55:10 UTC
I have 9 zones configured, all the same. Zone 1 water everyday while the rest no. How can I fix it? It does not need water everyday
浏览: 8106   回复: 1
pixie - water inside box and battery housing
veniamin
更新时间 2024-03-02 09:46:44 UTC
Pixie stopped to connect. Removed battery and found water inside battery housing. All contacts except one of battery are very rusty.
Trying to clean. Water also inside battery / battery box
Is it safe to dry and charge?
How to prevent water from entering the box?
浏览: 8364   回复: 1
Wifi icon
Carmelo Anaya
更新时间 2024-02-27 10:19:11 UTC
What does this WiFi icon mean?
浏览: 8546   回复: 1
Internet off - sprinklers on/off intermittently
Luke Johnson
更新时间 2024-02-17 22:49:05 UTC
We have an internet outage - Netro knows the smart watering cycle and continues to turn on through the stations at the correct time, however runs intermittently. 5 seconds on, 1 min off. Is there anything I can do to help stay on?
浏览: 8306   回复: 1
