Flow rate
Sander Z
更新时间 2022-03-14 12:34:05 UTC
浏览: 8177   回复: 1
Netro is watering at 25F because it is misinterpreted weather
Ben Aggus
更新时间 2022-01-11 12:15:06 UTC
I had to cancel watering because it’s 25F this morning. It’s because the weather is misinterpreted. The forecast today is 58/34, but that means it will be 34 for tonight’s low. Last night’s low was 25 and the Netro should look at that number for watering this morning.
浏览: 8823   回复: 1
Weather not updating
Mick Faulks
更新时间 2022-01-05 00:20:42 UTC
NetroWeather not updating, other weather apps only update if they are resubmitted every couple of days, is it possible to add other weather providers to the app?
浏览: 8619   回复: 2
arubalsky
更新时间 2021-12-01 13:44:22 UTC
Example:
Pixie 1 - Nov 24 - Good run
Pixie 2 - Nov 24 - Good run
Pixie 2 - Nov 26 - Good run
Pixie 1 - Nov 28 - Good run
Pixie 2 - Nov 28 - Good run
Pixie 2 - Nov 30 - Good run
浏览: 8357   回复: 1
changelives
更新时间 2021-11-13 23:40:38 UTC
Did I set it up incorrectly?
浏览: 8491   回复: 1
Forecast not updating
Jacques
更新时间 2021-11-07 10:29:17 UTC
浏览: 8919   回复: 1
更新时间 2021-10-05 10:53:54 UTC
浏览: 9108   回复: 1
Issue with Smart Watering
Davide
更新时间 2021-10-04 19:13:44 UTC
Hi Community!
浏览: 8229   回复: 1
Lee Stocks
更新时间 2021-09-25 01:02:17 UTC
浏览: 8266   回复: 1
Juan Pascual
更新时间 2021-09-22 17:57:24 UTC
Thank you very much.
浏览: 9147   回复: 1
Lots of questions!
Thomas Ingleton
更新时间 2021-09-22 13:39:22 UTC
浏览: 8434   回复: 1
更新时间 2021-09-07 09:58:44 UTC
浏览: 9216   回复: 1
Sean Eatch
更新时间 2021-09-01 01:08:02 UTC
浏览: 8833   回复: 1
更新时间 2021-08-31 09:42:59 UTC
DEEP
EPA
REGULAR
FREQUENT
Any advice?
浏览: 9064   回复: 1
% moisture
Julie Huynh
更新时间 2021-08-17 15:09:16 UTC
浏览: 10530   回复: 2
Moisture
cirujanoramirez
更新时间 2021-08-11 12:38:30 UTC
浏览: 8221   回复: 1
Weather Provider Error
Jacques
更新时间 2021-08-03 22:26:44 UTC
浏览: 8977   回复: 2
Rain sensor
更新时间 2021-07-26 12:13:34 UTC
浏览: 9138   回复: 1
wwhitfill
更新时间 2021-07-18 13:52:07 UTC
浏览: 8505   回复: 2
Internet down
更新时间 2021-07-18 11:38:25 UTC
浏览: 8951   回复: 2
