Whisperer and smartzone configuration
更新时间 2019-07-19 13:45:19 UTC
I have set up all the zones with the whisperers. And there is something I do not understand.
One of the zones usually get flooded in autumn because the type of soil retains lots of water.
But the whisperer and the smart zone is saying that the zone has to be watered more time than the other zones.
My question is if the whisperer adapts the irrigation schedules and the time is watering per zone. Depending on the moisture, weather conditions  and type os soil.  It is clear that the soil type determines how much and how often to water.
Here in the following link (https://www.netrohome.com/shop/products/whisperer)says that "Netro accurately measures the water capacity and drainage rate of your soil, making sure your soil always receives the perfect amount of water at the perfect time."
That is fine, but it is confusing that in the app I can still define the type of soil.
A second question I have is that I can define the watering strategy (Regular, ECO etc...) I want to know if the whisperer and the controller will notify me if I have to change the strategy based on the weather conditions and the type of soil, plants etc...
Any idea?
浏览: 9268   回复: 1
Doug Clark
更新时间 2019-07-07 18:06:07 UTC
This isn’t AI!
浏览: 8803   回复: 1
Reset Moisture Level
firewally
更新时间 2019-07-06 14:06:03 UTC
浏览: 8670   回复: 1
Forecast provider for Italy
Gabriele Gianello
更新时间 2019-07-03 11:53:03 UTC
浏览: 9430   回复: 1
Rain versus no rain
Dennis G
更新时间 2019-07-03 03:27:38 UTC
浏览: 9997   回复: 1
Yanke Liang
更新时间 2019-06-24 11:07:31 UTC
浏览: 9507   回复: 1
Jonathan B.
更新时间 2019-06-24 03:20:54 UTC
浏览: 10392   回复: 2
Start / End time
更新时间 2019-06-21 10:14:14 UTC
浏览: 9970   回复: 1
Not enough water
Robert Arnold
更新时间 2019-06-19 03:22:58 UTC
浏览: 9197   回复: 1
Simon Sollberger
更新时间 2019-06-18 20:39:36 UTC
浏览: 11177   回复: 2
Simon Sollberger
更新时间 2019-06-18 14:27:43 UTC
浏览: 9740   回复: 0
Netro's Rain Delay Feature
更新时间 2019-06-18 01:41:04 UTC
浏览: 11420   回复: 0
Zones Scheduled; Did Not Run
Matt O.
更新时间 2019-06-14 14:30:18 UTC
Good Day,
浏览: 9779   回复: 1
Dan Orms
更新时间 2019-06-13 18:06:42 UTC
浏览: 10036   回复: 1
Injector
richard.c.chapman@gmail.com
更新时间 2019-06-13 11:13:28 UTC
浏览: 9158   回复: 0
Watering zones twice
hjelmstadp
更新时间 2019-06-12 16:50:59 UTC
浏览: 9275   回复: 1
One Lawn, 2 Zones
Matt O.
更新时间 2019-06-11 16:07:07 UTC
浏览: 10891   回复: 2
更新时间 2019-06-05 01:59:12 UTC
To the Netro community:
浏览: 386912   评论: 24
Manually skip next watering
Randy Ziffer
更新时间 2019-05-19 16:47:13 UTC
浏览: 9627   回复: 2
Hot weather algorithm
Joshua Berk
更新时间 2019-05-17 16:15:51 UTC
浏览: 10488   回复: 2
