Rain adjustment
Arvind Ramanadham
更新时间 2020-03-31 19:10:38 UTC
浏览: 8246   回复: 1
Giacomo
更新时间 2020-03-24 14:44:34 UTC
Thanks in advance
浏览: 8683   回复: 1
Smart scheduling problem
更新时间 2020-03-23 19:15:51 UTC
This is my set up.
1) why this happened?
浏览: 8376   回复: 1
Javier Palomino
更新时间 2020-03-18 02:11:35 UTC
浏览: 7439   回复: 1
Sprinkler is on during rain
Wahid Ameni
更新时间 2020-03-14 00:12:38 UTC
浏览: 7814   回复: 1
Carlo D'Ippolito
更新时间 2020-03-01 14:55:14 UTC
Waiting for your feedback.
Kind regards
浏览: 8783   回复: 1
Claude Bedarride
更新时间 2020-02-29 14:28:34 UTC
浏览: 7527   回复: 1
new dripping system using Pixie and Whisperer
Markus Matula
更新时间 2020-02-20 08:52:39 UTC
I am in the process of designing my dripping system for my beach house in FL. I am thinking about using 2 Pixies and several Whisperers. I have several questions: 1) What happens when the WIFI is down? Does Pixie turn watering off/on on its own? 2) Does Pixie skip a watering cycle when raining? 3) Are the Whisperers connected to the Pixie and App in that the humidity information guides the amount and frequency of watering? 4) What is the recommended soil humidity for new planted palm trees? Thanks, Markus
浏览: 8628   回复: 1
Watering
Tim Foster
更新时间 2019-12-14 13:23:21 UTC
I have my first period of rain coming up, so the smart schedule isn't planning on watering until Christmas Eve. Since getting the sensors working properly I've been very happy with the smart watering, but the rain predictions here tend to be a bit sketchy. As my system is saying it won't water because there is rain expected, does it automatically adjust itself and water if the predicted rain doesn't arrive?
Also, I have it set to not water if expected rain is 5mm. What is the difference in this context between expectation and forecast?
浏览: 8182   回复: 1
Sangjin Lee
更新时间 2019-10-17 03:41:11 UTC
浏览: 8266   回复: 1
Weird watering plan
Manuel Roca
更新时间 2019-10-12 11:34:00 UTC
浏览: 7980   回复: 1
Tony D.
更新时间 2019-09-24 21:08:17 UTC
Hello everybody,
浏览: 8511   回复: 1
watering sequence
Gérard GALBOIS
更新时间 2019-08-26 18:23:46 UTC
It is unfortunatly not possible to change  in which ordre the watering will act.
for exemple I need to water zone 5 after zone 7 because zone 7 is at a higher level than the electro valve and remaining water pressure, after watering is stopped,  is to strong and prevents the valve to close . by watering supplemantary  zone 5 which is lower the pressure diminishes ans the valve of zone 7 closes..
浏览: 8046   回复: 1
How does a whisper sensor work with a drip system?
L F
更新时间 2019-08-25 23:46:33 UTC
I have a couple whisper sensors monitoring my lawn and drip system.   I understand how they can monitor the soil in my lawn but I’m wonder how the whisper works on my drip system as it doesn’t see the moisture that’s added to the soil(the emitter isolates the water to the plant) or the rate the plants use it like the one in the lawn does.  I’m assuming it’s just estimating like the Netro would on it’s own.  Is there much value to using a whisper on a drip zone?
浏览: 8537   回复: 1
Smart watering once a week?
Andrea D.
更新时间 2019-08-22 05:51:16 UTC
Hello there,
I'm new to netro and I tried to setup smart watering but the data I provided it will do it just once a week.
How is it possible? Is it safe to water just once a week?
浏览: 7899   回复: 1
Unexpected smart schedule
Tony D.
更新时间 2019-08-12 09:35:56 UTC
- zone 1: 6:00 16 min.
- zone 2: 6:17 15 min.
- zone 1: 6:46 16 min.
- zone 2: 7:02: 15 min.
UPDATE
Thank you in advance,
Tony
浏览: 8855   回复: 1
Runs for 9 hours at a time
Cindy Luvender
更新时间 2019-08-07 00:27:20 UTC
浏览: 8194   回复: 1
itsthesun
更新时间 2019-08-06 20:42:23 UTC
浏览: 8342   回复: 1
water amount
Gérard GALBOIS
更新时间 2019-07-31 05:37:55 UTC
浏览: 7855   回复: 1
30 minutes = 10 minutes X 3
Paul Como
更新时间 2019-07-27 11:49:20 UTC
How do I set my program to run each zone for 30 minutes each, but water 10 minutes 3 times each.  I thought this used to be an option, but I don’t see it.
浏览: 7755   回复: 1
