Seeding my lawn this week... How do I adjust the "New Plant" option for consistent watering?
Jonathan B.
更新时间 2025-10-20 22:59:45 UTC
Hi... since it's still fairly warm outside, I'd like to have the Zone water every 2 hrs for about 3 minutes just to keep the ground moisture up.
I'm not clear on how to do this?  Anyone?
浏览: 4544   回复: 1
Wind preference for drippers
Troy Robertson
更新时间 2025-10-17 06:46:57 UTC
Hey,
Is it possible to individually choose preferences for wind speed on a zone by zone basis? I've got some zones that are connected to sprayers which I would like to keep on a wind speed cutout and but most zones are on drippers which I would like to water independent of the wind speed.
浏览: 4441   回复: 1
更新时间 2025-10-08 13:12:52 UTC
浏览: 4467   回复: 2
Whisperer installation
Davide Chelo
更新时间 2025-09-26 11:38:17 UTC
Hi, I just bought the whisperer 2 and would like to have it as only sensor for the entire garden, however is allowed to have maximum 3 zones for sensor. Is there a way to link all the zones to it? I have 7 zones.
浏览: 4998   回复: 1
更新时间 2025-08-10 00:01:57 UTC
浏览: 4694   回复: 1
Watering time
Andrew Gor
更新时间 2025-07-23 14:36:45 UTC
I added the Netro whisperer 2 soil sensor to my ficus pot. The sensor gives me contradictory messages. It says that next watering should be in one week but every night it sends a notification to 'water the ficus sensor's. What should I do?
浏览: 5394   回复: 1
更新时间 2025-07-10 18:58:03 UTC
Kirk
浏览: 5426   回复: 1
WEATHER CONDITIONS - Rain
Zsolt Karman
更新时间 2025-07-08 10:23:15 UTC
Hi Team,
Could you please ?
Controller SN: 0cb815314670
Regards, Zsolt
浏览: 7819   回复: 1
更新时间 2025-06-25 16:41:56 UTC
浏览: 7313   回复: 1
Time range not respected
Fabio Silvestri
更新时间 2025-06-19 16:29:56 UTC
浏览: 7055   回复: 1
Ciccio Pasticcio
更新时间 2025-06-09 06:53:42 UTC
浏览: 7389   回复: 1
overwatering
更新时间 2025-05-20 12:55:43 UTC
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
浏览: 9136   回复: 2
Smart Zones are random
Dave H
更新时间 2025-05-19 15:27:46 UTC
Sprite-12
and/or
浏览: 8993   回复: 1
Panda88
更新时间 2025-05-15 18:20:45 UTC
浏览: 8738   回复: 1
Whisperer 2
Stephen Brewer
更新时间 2025-04-24 13:43:01 UTC
Steve
浏览: 8669   回复: 1
Matt
更新时间 2025-04-08 16:25:11 UTC
浏览: 8043   回复: 1
Discount
darla
更新时间 2025-01-30 20:05:17 UTC
Darla Carpenter
浏览: 9114   回复: 1
Netro offline
Brett Gardner
更新时间 2025-01-20 00:02:43 UTC
Suggestions?
Hard reset?
Brett
浏览: 8919   回复: 1
Fat Cut
更新时间 2024-12-29 07:11:04 UTC
浏览: 9027   回复: 1
Zine will not run
TJ Woods
更新时间 2024-10-27 14:40:45 UTC
浏览: 9356   回复: 1
