Whisperer GPS error
Guido Minciotti
更新时间 2023-05-10 15:11:55 UTC
浏览: 8503   回复: 1
Alexa
Federico Gietz
更新时间 2023-04-30 15:28:52 UTC
浏览: 7942   回复: 1
Jim
更新时间 2023-04-24 17:38:25 UTC
浏览: 8409   回复: 2
Matt Ward
更新时间 2023-04-14 13:57:11 UTC
Matt
浏览: 8665   回复: 3
Suggestions and Question.
Maurizio Gianesin
更新时间 2023-04-12 15:08:32 UTC
Good morning.
I just started using Netro Sprite 8 zones out of 12 zones with two whisperers.
Congratulations for the App and the Web interface I'm using.
I have a concern about some trivial errors in the interfaces:
If you go to settings/preferences/SchedulingSetting
1.1 The Italian translation of "Two Frames" in "Due Cornici" makes me smile, it is better translated in "Due Cicli" or "Due Fasi". But my suggestion is also for English : it is my opinion that if instead of "Time Frames" and "Two Frames" you use "Time Phase" and "Two Phase" it is much better also for English and automatic translations free from misunderstandings.
1.2 Only in the App and not on the Web, the description of the two phases has "afternoon" under "morning" and vice versa.
Now I have a question:
I ask you for an explanation on Smart Scheduling.
I had set a lower limit of 10 C° and a Time Phase of 6:00 - 10:00. When I removed the 10 C° limit, the system did the same day a cycle at 23:58 instead of waiting for 6:00. why?
I hope I have been helpful and thank you for any response.
浏览: 8066   回复: 1
Is Netro that smart?
Alessandro Alfei
更新时间 2023-03-16 00:53:44 UTC
why if Netro is so smart after months of learning with the whisperer still uses the "humidity to add watering" data set by me and doesn't create a custom program?  smartzone is in advanced level and regular mode.
浏览: 8709   回复: 2
Whisperer is suddenly crazy
JM del Amo
更新时间 2023-03-15 15:39:31 UTC
After a lot of time working fine, suddenly whisperer is crazy. With no reason suddenly the humidity is at "0" and the temperatures are above "90". I have cleaned with water the whispers. I have cleaned the device with water but remains doing same random mistake-
浏览: 8178   回复: 1
Smart zone manual setup
Vieri Verze
更新时间 2023-02-18 08:31:43 UTC
I do not understand how many millimeters to set. I have microsprinklers of 4lt/h and 2lt/h. I thought to set to 4000ml/h but the max is 100ml/h.
How to calculate? I have a big terrace with 30 plants and various microsprinklers.
Vieri
浏览: 8535   回复: 2
Reduce watering time in 1 zone
Ale Levi
更新时间 2023-01-22 19:32:59 UTC
Hi, I'd like to reduce the watering time in 1 zone which gets dumped each time Netro waters. The other zones are ok. Is there a way to do that in the smart mode? Maybe set an offset for that specific zone?
浏览: 7842   回复: 2
Customized moisture level not triggering watering
Richard
更新时间 2023-01-12 21:29:59 UTC
I have a Sprite with 3 Whisperers, all in the veggie patch.
I have the zones set to customize with a low of 25% and a high of 45% (I find 30 - 35 % moisture about right)
But the zones just won't get watered!
Zone 1 is down to 6% today and has been dropping steadily for days.
I HAVE to manually water, as the day time temperatures are consistently over 30 degrees (today 33, tomorrow 37).
Otherwise the plants will die.
Given there are only two values to enter (low and high). How do I stop the Netro from skipping days and putting the zones in the "Moisture" category??
浏览: 9819   回复: 1
LearNetro Whisperer
更新时间 2022-10-30 19:15:38 UTC
At the end of the whisperer's learning time, the times are set automatically in the program or have to be done manually?
浏览: 9461   回复: 2
Main feeder line shutoff valve control
Richard Miles
更新时间 2022-10-10 02:16:36 UTC
My main water line to the sprinkler system came loose and flooded my vacation home yard with 250,000 gallons of water before the leak was discovered and repaired.  Does Netro have the ability to control an electric valve on this feeder line such that the main valve will only open when the irrigation system calls for water?
浏览: 8448   回复: 1
Mulch impact on duration
John Wright
更新时间 2022-09-13 12:58:29 UTC
浏览: 8435   回复: 1
更新时间 2022-09-10 12:26:33 UTC
浏览: 8938   回复: 1
How many rain sensors?
Roland Pircher
更新时间 2022-09-01 17:53:32 UTC
浏览: 8151   回复: 1
Error in watering ?
Davide M.
更新时间 2022-08-29 11:31:56 UTC
Please help me:
  1.  what should I trust ?
APP:
WEB:
浏览: 8859   回复: 1
rbrodt
更新时间 2022-08-25 16:29:00 UTC
浏览: 8511   回复: 1
texan4ever521
更新时间 2022-08-24 20:24:11 UTC
My settings :
soil type: clay
sprinkler type: rotor head
shade: none or some shade
浏览: 8658   回复: 1
Can Pixie measure water flow?
更新时间 2022-08-23 14:09:01 UTC
浏览: 8696   回复: 1
Joshua Dunn
更新时间 2022-08-16 11:00:28 UTC
浏览: 8201   回复: 1
