ALGORITHM FLOW RATE
Javier NM
更新时间 2023-07-20 07:08:54 UTC
浏览: 8846   回复: 1
Andrea Vecchia
更新时间 2023-07-17 14:34:51 UTC
浏览: 8215   回复: 1
Weather underground
Dion Friedt
更新时间 2023-07-17 03:09:10 UTC
浏览: 8135   回复: 1
Watering even when it's wet
Jure
更新时间 2023-07-16 14:14:17 UTC
浏览: 8536   回复: 1
Why no cycle soak setting?
更新时间 2023-07-08 19:56:33 UTC
浏览: 8774   回复: 1
Pixie Z1
ke7vng
更新时间 2023-07-08 02:25:00 UTC
浏览: 7984   回复: 1
Not enough watering
Manuel Herbst
更新时间 2023-07-03 20:19:28 UTC
Hey everybody,
Can anybody help me?
Manuel
浏览: 8563   回复: 1
Cambio días de demora.
Lino
更新时间 2023-07-03 06:35:04 UTC
浏览: 8247   回复: 2
更新时间 2023-06-27 08:48:51 UTC
浏览: 8717   回复: 1
更新时间 2023-06-26 12:06:15 UTC
  1.  it's raining or
浏览: 8555   回复: 1
Zones not watering
joefil
更新时间 2023-06-22 16:54:38 UTC
Your help is appreciated
浏览: 8098   回复: 1
Start-end time not working
Fabio Silvestri
更新时间 2023-06-21 05:20:31 UTC
浏览: 8616   回复: 3
更新时间 2023-06-19 09:25:40 UTC
浏览: 8782   回复: 2
更新时间 2023-06-10 17:50:24 UTC
浏览: 8603   回复: 1
更新时间 2023-06-09 06:07:25 UTC
2.Smart watering: Level basic
3.Smart-zone feature disabled
浏览: 24030   评论: 12
Custom sprinkler flow rate
Jure
更新时间 2023-06-01 14:42:27 UTC
浏览: 8435   回复: 1
New grass from seed
D Berggren
更新时间 2023-05-31 01:11:58 UTC
浏览: 8130   回复: 1
Rotor head
Sjors Janssen
更新时间 2023-05-25 19:15:07 UTC
I've just been using a Netro Spark to water my garden. I have set up 3 zones. Two of these zones have a rotor head sprinkler. However, they don't cover the same area. One of them rotates over 90 degrees. The other rotates 180 degrees. So I think the rotor head that covers the 180 degrees needs to run double the time of the 90 degree one. How can I set this? I've set the sqm for each head, but smart irrigation used the same times for both.
Kind regards,
Sjors
浏览: 8009   回复: 1
Update the irrigation routine according to the updated weather forecast
Luis T
更新时间 2023-05-24 15:44:31 UTC
Hi there!
I live in Madrid, Spain and use AccuWeather as my weather provider, since NetroWeather does not provide a correct forecast for this area for some reason.
This week we have had heavy rain forecast so Netro will not activate the irrigation system for several days. The problem is that as the day goes by the forecast is changing and Netro's planning is not updated.
It has already been several days in which according to the initial forecast, it was supposed to rain and it did not, so I have had to launch manual irrigations.
Is there any way to force the smart irrigation program to update according to the new weather forecast?
浏览: 8916   回复: 1
Bruno
更新时间 2023-05-10 22:41:29 UTC
浏览: 8571   回复: 1
