更新时间 2026-08-06 07:50:00 UTC
Dear Netro Community,
What We Are Doing
📧 support@netrohome.com
Best regards,
Netro Support Team
浏览: 10066   评论: 0
Can’t get water to work
Ally P
更新时间 2024-05-07 18:45:51 UTC
I moved into a house with the Sprite 6 system and have it fully set up on my phone, however can’t get the water to actually run. I haven’t touched anything. Any advice?
浏览: 9927   回复: 1
How to remove rain delay
Gyanendra Kumar
更新时间 2022-08-18 19:35:45 UTC
浏览: 11343   回复: 1
New Braunfels Utilities stage 3 restrictions
Elisha H
更新时间 2022-07-19 18:08:31 UTC
We currently are under stage 3 restrictions, every other week on certain days. Photo to follow showing our restrictions & the smart app restrictions.
浏览: 11213   回复: 2
Netro Spark question
Robert Dambrosio
更新时间 2022-06-12 20:59:09 UTC
浏览: 11246   回复: 2
更新时间 2022-05-23 14:33:07 UTC
浏览: 10999   回复: 1
Gaspare Miceli
更新时间 2022-04-18 06:23:55 UTC
浏览: 11135   回复: 1
UK watering restrictions
更新时间 2021-06-01 11:26:19 UTC
Cheers,
Andy
浏览: 11871   回复: 1
Disable a zone
fernando colon
更新时间 2021-04-10 14:15:21 UTC
浏览: 11659   回复: 1
更新时间 2019-12-25 01:46:02 UTC
To the Netro Community,
浏览: 15102   评论: 0
Location Based Watering Restrictions - Check-in Interval
Matt Grooms
更新时间 2019-07-14 18:58:52 UTC
One of the great features of Netro is it's ability to look up my local (city/state) watering regulations, and apply them to my watering schedule. Bravo Netro!
Months ago, when I installed my Netro controller it looked up the then current (Stage-One) restrictions, and applied them to my watering schedule. However, since that time the watering restrictions have been eased (Year-Round restrictions) , and I'm allowed to water any day of the week. Well, Netro did not follow the changes and is still applying the old restrictions.
I attempted to trick Netro into rereading my local restrictions by turning the feature off, then back on. No luck.
So the questions are:
1) How often does a Netro Controller check the cloud database for updated watering restriction for it's location?
2) How often does Netro Central (you guys) check with communities for watering restriction updates and update your database so that deployed Netro controllers get accurate rules to apply?
I can see where it might be hard to keep up with small communities and rural areas, but my location (San Antonio, Texas, USA) has almost two-million people in the area. A single update on your part would provide a potentially large number of Netro users with current watering restriction information.
Matt
浏览: 15164   回复: 1
Netro + Netatmo
Luca Magnani
更新时间 2019-07-14 07:42:29 UTC
Good morning
I have a netatmo weather station,
it would be nice to connect it to read the weather data precisely for my area.
Thank you in advance
浏览: 15724   回复: 1
Military time
Matty B
更新时间 2019-06-05 14:34:21 UTC
Can the time be changed on the schedule to AM/PM and not 24/hr clock?
AccuWeather.com if selected waters in the AM. If i switch it to the other 2 it changes the schedule to PM watering. What is the reasoning behind this? I would prefer AM watering but would like to use a different weather provider.
浏览: 14992   回复: 1
更新时间 2018-06-04 10:03:46 UTC
References
浏览: 17376   评论: 0
