[Community Vote] Shape Our Next Update: Vote for Your Top 3 Most-Wanted Features!
更新时间 2026-11-09 09:12:06 UTC
Dear Friends,
First and foremost, a heartfelt thank you to everyone for your continuous feedback, suggestions, and vibrant discussions! We carefully review every single comment across our community—your hands-on garden management experiences are the greatest driving force behind Netro’s continuous growth and iteration.
We have compiled the 9 most frequently requested features and enhancements from your recent feedback. To make sure our development resources go directly toward what matters most to you, the priority of our next update is entirely in your hands.
👉 Voting Rules: Please select up to THREE (3) features below that you would most like to see implemented. The 3 items with the highest votes will officially enter our upcoming first-round development and optimization schedule!
The vote is officially live—come cast your 3 votes! If you have any specific ideas or thoughts on how these features should work, we would love to hear from you in the replies.
Thank you once again for your ongoing support, and let’s keep building a smarter, more thoughtful garden watering experience together!
Netro Support Team
浏览: 383   评论: 2
更新时间 2026-11-09 02:24:03 UTC
Then you should put Sprite in "paused" mode just in case some one (for example the kids) accidentally starts a manually run from the app. To put Sprite in "paused" mode, you can go to the Home page-> "Enabled".
浏览: 15539   评论: 1
Programs transfer to a new device
Giacomo
更新时间 2026-09-22 12:08:53 UTC
The day before yesterday my 12-zone Sprite died after 7 years of loyal service; I was hoping it was the AC power adapter, but the multimeter says everything is OK. I ordered a new Spark on Amazon, and my question is whether I can transfer the programs to the new device or if they are tied to the old one.
Thanks in advance for your replies
浏览: 1219   回复: 1
Dark Mode- Font Size
更新时间 2026-09-01 12:47:57 UTC
[I posted a request for an update on this feature request submitted and confirmed for the roadmap back in 2022 but had no reply after two months so starting new thread]
浏览: 1434   回复: 1
May 31, July 31, Aug 31 restriction
Dave H
更新时间 2026-08-25 22:13:52 UTC
Can the app be configured to not run on my May 31, July 31 and Aug 31 restrictions? How? I can't figure it out
浏览: 1549   回复: 1
Soil Moisture Readings
dougt425
更新时间 2026-08-06 16:06:01 UTC
I currently have several Netro Whisperer 2 sensors and receive moisture, temp and solar readings. But i also have other soil sensors - e.g., Ecowitt. The two sensors appear to measure soil moisture on different scales. Can someone - from Netro - explain to me clearly how the Whisperer measures moisture and how I should interpret different readings in the same bed (e.g., Ecowitt measures 28%, Whisperer measures 96%).
浏览: 1791   回复: 1
更新时间 2026-08-06 07:50:00 UTC
Dear Netro Community,
What We Are Doing
📧 support@netrohome.com
Best regards,
Netro Support Team
浏览: 9970   评论: 0
Controller
rodrigo6760
更新时间 2026-07-10 12:33:26 UTC
Cómo puedo borrar un controller que aparece en la app y que ahora ya no está funcionando ? Aparece fuera de línea y no puedo borrarlo.
Muchas gracias
浏览: 2101   回复: 1
Notificaciones
Peter urrielu
更新时间 2026-06-14 07:59:40 UTC
Hola, en la sección de notificaciones de la aplicación, no hay nada, no hay ningún tipo de notificaciones para elegir. Es un problema de la versión de la aplicación o es un problema mío?. Gracias
浏览: 2483   回复: 1
Massmo Tommasi
更新时间 2026-06-06 13:21:26 UTC
grazie
浏览: 2165   回复: 1
Irrigation
Antonio Cordon Rodriguez
更新时间 2026-05-21 19:28:42 UTC
浏览: 3927   回复: 2
Greenhouse zone
Ivan G
更新时间 2026-05-20 08:59:47 UTC
浏览: 3861   回复: 1
New feature request
更新时间 2026-05-10 19:34:04 UTC
浏览: 2500   回复: 1
programs - status sign
Lee Hill
更新时间 2026-05-08 06:45:32 UTC
Developers, can you add some indication to list of programs to see which is enabled, which is not?
Instead of going into each and scroll to the very bottom to check 'enabled'.
I think of either being grayed out or adding a sign, whatever simplest may work.
thank you
浏览: 2485   回复: 1
programs - reordering
Lee Hill
更新时间 2026-05-08 06:40:14 UTC
浏览: 2528   回复: 1
Notifications sur Android
Cyrille ROBINET
更新时间 2026-05-03 16:14:14 UTC
Bonjour,
J'aimerais avoir de l'aide.
Merci
浏览: 2599   回复: 1
enable switch
Andrew McNaughtan
更新时间 2026-04-19 22:32:06 UTC
I switched the enable switch in the Netro app to disable and now I can't get it to turn back on. The app says "next run not scheduled". When I close the app and reopen it, the switch has moved back to the disabled position. Nothing works, I can't even manually water. The controller has a green light showing and I have tried powering the controller off and back on and it reconnects without an issue but the app will not work.
浏览: 3171   回复: 1
Multiple locations
paul.robinson@bigbend.net
更新时间 2026-04-12 21:06:55 UTC
浏览: 3229   回复: 1
Combine 2 zones
Alexis Demosthenous
更新时间 2026-04-07 03:33:14 UTC
Hello everyone,
For my lawn i have 2 watering zones, is there a way to "force" schedule to combine those 2 zones to always follow each other? I dont want to water half my lawn on Monday and the other half on Thursday.
浏览: 3258   回复: 2
Will
更新时间 2026-03-17 21:54:57 UTC
浏览: 4297   回复: 3
