App Netro
Antonio Cordon Rodriguez
更新时间 2024-04-28 09:28:48 UTC
浏览: 7897   回复: 0
Fabio F
更新时间 2024-04-20 14:28:45 UTC
 How do I solve this problem?
浏览: 8664   回复: 4
Bob Cohen
更新时间 2024-04-15 23:49:36 UTC
浏览: 8276   回复: 2
Exclamation on Schedule
Oilol
更新时间 2024-04-10 12:56:31 UTC
Thanks in Advance!
Tim
浏览: 8018   回复: 1
2 whisperer to 1 pixie
Paolo S
更新时间 2024-04-02 20:28:39 UTC
浏览: 8545   回复: 1
Forecast doesn't show
Edan Manos
更新时间 2024-03-31 05:34:57 UTC
浏览: 7993   回复: 1
Manual Operation
Mario Hardy
更新时间 2024-03-21 12:47:06 UTC
浏览: 8318   回复: 1
Multiple watering a day
Phil Rubin
更新时间 2024-02-17 04:33:52 UTC
I need to run watering programs 2-3 times in a day, every day. I have "two fra m es" checked but it only will do one.  What do I  need to do?
浏览: 8452   回复: 2
Pump
Carmelo Anaya
更新时间 2024-02-12 20:44:48 UTC
I have 6 zones but only 4 require to switch on the pump. How can I switch the pump individually on each zone?
浏览: 8070   回复: 1
Port 1883 is blocked by the touter
Gary Harpley
更新时间 2024-02-10 05:49:13 UTC
Hi. Im a new user and everytning seems to be working ss it should but i get the following message when i check the server status
浏览: 8016   回复: 1
Weather Underground
Gary Harpley
更新时间 2024-02-06 06:06:14 UTC
Hi. The app wont let me add my wundergound id number (IWAGGA24). Can you please help
浏览: 8046   回复: 1
Data records
David Lrx
更新时间 2024-02-03 12:14:57 UTC
Is it possible to upload data from the app so I can keep record on an externat file for more than a month ?
I would like to keep record for a year long.
David.
浏览: 8005   回复: 1
Manual run times need to be longer and editable while running
Richard
更新时间 2024-01-19 21:27:13 UTC
Hi Netro,
One frustration I have is that manual run times are important to me but cannot be longer than 1 hour (or programs) and cannot be adjusted while running.
I have Netro connected to a solenoid that controls watering of our small vineyard.
I rarely water in any way other than manual, because I need to control the amount of watering and also use fertigation to feed the vines.
Due to the amount of water required, I need between two to three hours of watering. I also like to adjust as I go, depending on how long the fertigation takes, so the ability to increase time without stopping the watering is also important.
My other solution is to disconnect the wire from Netro and use a Shelly 1 instead, whereby I can turn the watering on and off as I desire.
I would rather just use the Netro app, given that everything is already connected.
It is quite limiting to not allow hours as well as minutes (or to allow more than 60 minutes). amd not to be able to increase (or decrease) the time while the manual run is going.
浏览: 9029   回复: 2
PM Time
Cacho
更新时间 2024-01-01 15:43:35 UTC
Hello again, i found that i can set night times on the webpage, and it get sets on the app after that.   But if i try from the app i cannot set any night times.
浏览: 8221   回复: 1
Stand alone Whisperer 2 Sensor
suddath
更新时间 2023-12-30 17:56:29 UTC
We have a Netro Pixie that we have been using to water trees in our backyard.
We purchased two Whisperer 2 sensors to help understand how much to water.
We paired and installed one sensor which is linked to the Pixie.  This sensor works well and reports light, moisture and temperature and appears in the app in the zone watered by our Pixie.
The other sensor installed as "standalone".  This sensor does not show up on our app including in settings.
How do we access this "standalone" sensor or data?
thank you.
浏览: 8336   回复: 1
Pixie & Wisper 2 - How to get them to connect?
Mark Smith
更新时间 2023-12-08 08:15:08 UTC
I have purchased 3x Wisper 2s and 3x Pixies as well as a Spark. I want to set the watering frequency based on information from the Whispers. In the app, it has a sensor field, but it's not selected. I can't find any instructions on getting them to work together. I opened a ticket with support 2 days ago but no response.
浏览: 8914   回复: 2
Home Assistant integration
Homestead One
更新时间 2023-12-01 14:54:03 UTC
Hi guys,
Is it possible to integrate nestro smart sprinkler to home assistant?
Thx!
浏览: 8560   回复: 1
Meaning of Pie-Chart Illustration in Sensor Graph
Mark
更新时间 2023-11-16 08:54:15 UTC
Hi there, Ive noticed that some of the pie-slices in the moisture/temperature/lux graphs from my Whisperer Plant Sensors are heavily coloured (darker) and some are lightly coloured (lighter). Is this supposed to indicate something?
I suspected that maybe the difference in colour reflects upload as either live (or cached), but I double checked and they all have >50% wifi connection strength and report regularly...
浏览: 8364   回复: 1
PROGRAMS. "NOTES" FIELD
Javier NM
更新时间 2023-11-02 07:49:07 UTC
I am using Netro software with a Sprite-6 controller. After some moths use I am delighted with the system. The tools it provides help me a lot controlling my garden, with good results. Congratulations. Normaly I use three out of my four zones in Smart (advanced) mode, and the fourth one in Smart (Basic).
I would be useful if we could have a field (name it "Notes" or similar) so that we could enter useful information about the use of each individual program (for example, "I reduced frecuency to alternate days after Oct 15th", or other information.
Not having that field causes useful feedback not to be available when managing programs.
浏览: 8735   回复: 1
Sprite 12 Controller Problem
John LaRocca
更新时间 2023-10-14 01:42:23 UTC
浏览: 8244   回复: 1
