RKR Home
更新时间 2026-03-03 03:32:35 UTC
浏览: 3344   回复: 1
Supported Hardware
Colin Brierley
更新时间 2026-02-12 06:13:48 UTC
浏览: 3732   回复: 1
Feature Request
John Sirois
更新时间 2026-02-10 05:56:14 UTC
John
浏览: 3256   回复: 1
Notification
Alexis Demosthenous
更新时间 2026-02-05 19:28:19 UTC
浏览: 3437   回复: 1
Shane V
更新时间 2026-01-19 04:54:45 UTC
浏览: 3439   回复: 1
Giardino
Nelu Iftime
更新时间 2025-10-20 08:18:25 UTC
Sistemato
浏览: 5642   评论: 0
Can't login
更新时间 2025-10-13 15:40:38 UTC
This morning we noticed that my Sprite light was flashing. I tried to get into the app and it kept saying network error. I booted the Sprite, I booted my router, and the light is no longer flashing.
But when I try to log into the app now it says network error. I logged into metrohome.com and my Sprite was able to work from naturalhome.com, but I am still not able to log in to the app. I use the same login at netrohome.com as I did with my app.
浏览: 5016   评论: 1
Password
Ignacio Sánchez
更新时间 2025-09-26 11:38:52 UTC
浏览: 4794   回复: 1
Info function
Giuseppe
更新时间 2025-09-20 09:48:50 UTC
浏览: 5340   回复: 1
Time
Silvano Scotto
更新时间 2025-09-10 23:18:59 UTC
浏览: 6074   回复: 1
Francesco Gritti
更新时间 2025-08-29 16:39:06 UTC
浏览: 6742   回复: 1
help Netro Spark 6
Andrea Giannelli
更新时间 2025-08-14 09:03:33 UTC
Hi everyone,
Despite these attempts, the problem persists.
Thenks
浏览: 6846   回复: 1
Change zone order
Matt Ward
更新时间 2025-07-22 00:43:18 UTC
浏览: 7606   回复: 1
Whisperer low battery alert
Jesus Sanguinetti
更新时间 2025-07-19 15:24:34 UTC
浏览: 7335   回复: 1
Pause
Tamgar chan
更新时间 2025-07-19 10:59:15 UTC
浏览: 7238   回复: 1
Spark 8 zones
Jesus Laso
更新时间 2025-07-10 13:05:31 UTC
Good afternoon,
Thais in advance
浏览: 7357   回复: 1
Sensors missing
dano
更新时间 2025-07-06 00:06:15 UTC
Dan
浏览: 7371   回复: 1
Gyade B.
更新时间 2025-07-03 23:32:35 UTC
浏览: 7262   回复: 1
Wifi error
nvenezia
更新时间 2025-07-02 14:51:10 UTC
浏览: 7232   回复: 2
Unified controllers
Gianluca Spada
更新时间 2025-06-29 20:59:51 UTC
浏览: 6946   回复: 1
