Replace controller
paul.robinson@bigbend.net
更新时间 2024-08-24 22:53:15 UTC
浏览: 7767   回复: 1
problematiche app
Giampaolo Mariani
更新时间 2024-08-20 08:16:25 UTC
浏览: 7746   回复: 1
Boost factor in app
Jorge Castrillo
更新时间 2024-07-30 13:55:17 UTC
浏览: 7848   回复: 1
Manual watering beta
Lynn johnson
更新时间 2024-07-10 04:17:16 UTC
浏览: 7860   回复: 1
Increase Run Time Per Zone
Don Carli
更新时间 2024-07-04 18:58:45 UTC
Don
浏览: 8177   回复: 2
Steve M
更新时间 2024-06-30 23:53:31 UTC
浏览: 7721   回复: 1
Adjusting for tree cover
Steve M
更新时间 2024-06-30 23:47:30 UTC
浏览: 7668   回复: 1
app crashing
Christoforos
更新时间 2024-06-28 14:13:56 UTC
Can you please help.
Christoforos
浏览: 7696   回复: 1
Where is the documentation on how to use the app?
Lance Blaise
更新时间 2024-06-20 03:41:17 UTC
Where is the documentation on how to use the app? I have no clue how to set my own schedule or how to use the smart scheduling... I can't find anything on how to use this app at all and it's pretty confusing. I am looking at the app and it seems to have smart watering enabled, but there are times where it's skipping 3 days randomly and there is no rain that is supposed to take place on those days, so no clue why it's skipping those days. Can someone direct me to where the documentation is for using the app?  Thank you.
浏览: 7696   回复: 1
network error
更新时间 2024-06-18 10:24:07 UTC
i have a Netro app
on ios with a 12 station
Starting this morning i receive a
Network error message
i restarted/ re connect
same message
May i need a new firmware ?
浏览: 8592   回复: 3
Change whisperer mode
Jure
更新时间 2024-06-15 11:33:22 UTC
What is the proper way for changing Whisperer from standalone mode to adding it to my Netro Pixie or Sprite?
浏览: 7781   回复: 1
Where to see Whisperer data collected in the Netro App ?
JDo REY
更新时间 2024-06-07 09:01:29 UTC
Where to see Whisperer data collected in the Netro ?
浏览: 7833   回复: 2
Rainbird R Van rotator
更新时间 2024-06-04 19:09:06 UTC
Hi there
浏览: 8336   回复: 3
Shut off one zone
Wil
更新时间 2024-05-31 04:05:40 UTC
浏览: 7928   回复: 2
Javier NM
更新时间 2024-05-26 06:32:56 UTC
浏览: 8238   回复: 1
PREFERRED ARTICLES
Javier NM
更新时间 2024-05-12 06:36:42 UTC
浏览: 8342   回复: 1
Help!
John Zuzula
更新时间 2024-05-02 14:46:09 UTC
浏览: 8032   回复: 1
Manual operation doesn’t stop
Ciro Bracciante
更新时间 2024-04-29 11:31:14 UTC
浏览: 7645   回复: 1
App Netro
Antonio Cordon Rodriguez
更新时间 2024-04-28 09:28:48 UTC
浏览: 7685   回复: 0
Fabio F
更新时间 2024-04-20 14:28:45 UTC
 How do I solve this problem?
浏览: 8487   回复: 4
