Potted plant on terrace
Andrea Zorgniotti
更新时间 2020-09-14 07:46:03 UTC
Hi I Have a big terrace with many plants divided in 3 zone controlled by Netro. To use the smart watering and have an acceptable time/frequence for watering (6 min every 2.5 days) I have to set user and from 80% to 85% umidity. If I set frequent or extra water the estimated frequency is 4/5 days. Considering in summer my setting seems nor giving enough water to plants what kind of setting do you suggest to increase the frequency (change msq, kind of sprinkle or whatever).
Thanks in advance for answer
浏览: 7502   回复: 1
Way to add weather stations
Curt Lizzi
更新时间 2020-09-12 01:16:55 UTC
I find the Weather apps to be very inaccurate with respect to rainfall at my home. Is there a way to add a near by weather station for better accuracy?
浏览: 7590   回复: 1
Sensor watering adjustment doesn't work - bug
Roman Stanek
更新时间 2020-09-04 04:49:34 UTC
I installed two sensors today and added watering adjustment so that every time the humidity goes below 10% another 10 minutes of watering is added. Unfortunately, there is a bug and the watering time is triggered right away even though the faucet timer connects only every three hours. The additional watering time needs to be scheduled after the next timer sync and not right away. It's a clear bug.
浏览: 7242   回复: 1
Keeps watering even though it rains
Oleg Frayman
更新时间 2020-09-02 01:51:56 UTC
My sprinklers keep watering even though skipping if it rains is selected with low threshhold
浏览: 7010   回复: 1
Lost connection on holidays
lekter
更新时间 2020-08-12 08:45:08 UTC
I'm on vacation and my internet connection has been cut off. I had planned before on netro waterings for the week. Is that without an internet connection in my house, the waterings programmed before will still be done?
Arnaud
浏览: 7601   回复: 2
Smart watering
Alejandro Foubelo
更新时间 2020-08-07 01:27:29 UTC
Hello, I set the app to run 3 manual programs on the odds day and I have the smart watering system active on all zones.
Will it skip my watering if there is rain in the forecast on an odd day?
浏览: 7436   回复: 1
Confused about schedule
Bowie Xu
更新时间 2020-08-04 18:52:19 UTC
I am a new user here and just installed the Netro in my house. The “Smart watering” schedule seems very odd to me.
As you can see there are 2 rounds for each zone and the time of zone 4 is about an hour in one round. Is this normal ?
Bowie
浏览: 7851   回复: 1
Watering "off the books"
wwhitfill
更新时间 2020-08-02 23:26:54 UTC
Right now the watering schedule the Netro program is using for my St. Augustine grass is killing my grass. I live in Dallas and Jully/August is brutal on lawns. If I water outside the schedule the program has established the schedule is changed. Is there anyway for me to water my with Netro and keep the smart watering schedule Netro has? Right now I by pass the Netro by manually engaging my water values, not using Netro.
Will
浏览: 7349   回复: 1
Water turned off
Ken Laberteaux
更新时间 2020-07-31 01:08:39 UTC
I had to turn off my water valve to my sprinkler system for a week (ending in a few days) and forgot to disable smart watering on my netro.  Netro thinks it did a complete watering last Saturday, and adjusted estimated soil moisture accordingly.  Netro isn't planning another watering for another 9-10 days.  However no watering last Saturday occurred.
How best should I handle this?  Is there a way to delete past watering, which will lower soil estimated moisture, triggering a sooner watering than currently scheduled?  Or should I just do a manual long watering as soon as I can?
浏览: 7735   回复: 1
更新时间 2020-07-28 05:32:10 UTC
I have an issue/conflict  with the watering adjustments for the sensors and the Smart Zone Sheduling
I have seen something weird.
  • I Have set up the Watering Adjustment for sensors the following I describe o be sure about the problem
  • Moisture to Skip watering 50%
  • Moisture to Add watering 30%
  • Duration 5 minutes (only) -- it is a check
  • The Smart Zones are st up the following
  • Smart Zone - enabled
  • Mode - regular
The watering run today only 5 minutes, when the smart  schedule  defined by the system was above that. As you can see, tomorrow watering says different time runs per zone, but it will run a maximum of 5 minutes. This means that the sensor configuration overrides the Smart Zone. And it should not.
As far as I understand the Watering adjustemt is to add EXTRA watering when needed based on the moisture level. Attached picture
Prior to this setup I had the Duration for Watering Adjustment for 15  and 10 minutes, and you can see in the past days runs, that always run for 15 -10 minutes depending the zone/sensor. - Attached picture
In previous weeks, it was working fine and adding extra watering when need it to keep the moisture levels.
Any idea?
I DID THE CHANGES PROPOSED BY NETRO  and it is not working
Take a look the screen shots
Zones 3,4,5 it is below the 30% trigger
浏览: 8100   回复: 1
I'm not understanding how "estimated frequency and duration" works...
Izio Sem
更新时间 2020-07-18 07:24:18 UTC
Ciao.
Just installed Netro Sprite.
I enjoyed to set up the zones with advanced Smart watering, but I'm not confident with what is reported in "estimated frequency and duration". The frequency showed in the setting page seems too long (e.g. every 6 days)... but, if I see what is scheduled in the calendar it seems much closer to my expectation (e.g. every 2 days).   How daoes it work??
Maurizio
浏览: 7908   回复: 1
Does Netro whisperer underestimate moisture?
Rick Agrawal
更新时间 2020-07-16 19:12:17 UTC
I added a whisperer to one of our zones. Recently the moisture content was between 25-30%. We are having a hot summer with many days with 110 degrees. I believed it and watered for good 15-20 minutes. It turned out despite all those water the soil moisture went up to 45-50%. I went and checked again, the soil looks pretty good and appeared moist.
Just curious if the whisperer tends to underestimate moisture?
浏览: 7296   回复: 1
Watering Frequency
Andrei Stancovici
更新时间 2020-07-16 05:36:44 UTC
Hello.
I installed my netro yesterday and now after watering all zones it shows me that the next watering will be in 5 days. It seems to be to far away in the future since it's 35 degrees celsius and sunny all day
浏览: 7103   回复: 1
Smart watering issue?
Ananth
更新时间 2020-07-15 13:14:40 UTC
浏览: 7917   回复: 1
user manual in spanish
Alejandro
更新时间 2020-07-14 10:00:20 UTC
浏览: 7634   回复: 1
Not enough watering time
Homestead One
更新时间 2020-07-08 20:04:00 UTC
I have 4 zones activated.
Please help.
浏览: 7795   回复: 1
Arthur
更新时间 2020-07-08 16:08:19 UTC
浏览: 7297   回复: 1
Hozelock
Alan George
更新时间 2020-07-06 18:50:08 UTC
浏览: 7268   回复: 1
sw238
更新时间 2020-07-05 15:42:38 UTC
浏览: 7378   回复: 1
Michael Fortwengler
更新时间 2020-07-04 19:06:14 UTC
浏览: 7198   回复: 1
