Whisperer Test
Dan Leng
更新时间 2019-07-10 18:29:27 UTC
浏览: 10054   回复: 2
更新时间 2019-07-07 14:40:49 UTC
浏览: 10825   回复: 1
Saurik
更新时间 2019-07-04 07:12:42 UTC
浏览: 9569   回复: 1
更新时间 2019-07-01 16:32:17 UTC
浏览: 9938   回复: 1
internet may not be available
Bruce Vermeulen
更新时间 2019-06-30 18:31:02 UTC
Bruce
浏览: 9176   回复: 0
WiFi connection
Andrew
更新时间 2019-06-27 00:49:26 UTC
浏览: 8995   回复: 0
Remove whisperer
Dan Orms
更新时间 2019-06-25 16:17:24 UTC
浏览: 9797   回复: 1
Disconnecting Constantly
Kate Whelan
更新时间 2019-06-09 18:05:15 UTC
My Netro Smart Sprinkler Controller, WiFi, Weather aware, Remote access, 6 Zone, Compatible with Alexa disconnects CONSTANTLY from the app/network and I’m about to put back on our old school controller. Today it disconnected IN THE MIDDLE of watering the lawn while I was feeding/putting my baby down for a nap and it ended up watering for 28 mins, flooding my backyard. Ugh.
Any tips on fixing this? I do not have intermittent internet or power issues. Is there a hardware update? Aside from this, I LOVE it - but this is kind of a deal killer for me. I plan to call customer service on Monday, but thought I’d check here for tips to see if I can fix it sooner.
浏览: 10595   回复: 1
Not watering on any zone
A Miller
更新时间 2019-06-02 18:39:10 UTC
The sprite worked perfect for about 3 weeks. Went out of town for a week, during that time it snowed for the entire duration of my trip. The unit worked as it should and didnt water. However when it should have picked up its schedule after weather cleared it did not. It will not run its zone at all. I have checked the resistance on all zones solenoids and they are fine at 28 ohm. I reconnected my old hunter system and all zones worked properly with that controller. So whats the next step?
浏览: 16239   回复: 1
Constant Blinking
Seth McDonald
更新时间 2019-05-31 00:32:04 UTC
My device appears to be connected and working, but I noticed the light on the unit is blinking constantly.  Is it supposed to be doing that?
浏览: 9385   回复: 1
Don’t Stop !!
Eduardo Ariste
更新时间 2019-05-26 11:27:42 UTC
浏览: 9115   回复: 1
jpmeyer81
更新时间 2019-05-19 15:04:11 UTC
浏览: 9575   回复: 1
Roianne Cox
更新时间 2019-05-19 13:52:50 UTC
浏览: 8938   回复: 1
Dennis N
更新时间 2019-05-18 17:52:30 UTC
浏览: 9001   回复: 1
David Claridge
更新时间 2019-05-18 13:21:53 UTC
浏览: 9025   回复: 1
John Locke
更新时间 2019-05-05 14:16:12 UTC
浏览: 9667   回复: 1
John Mac
更新时间 2019-04-22 23:42:30 UTC
浏览: 9104   回复: 1
Nathan Anderson
更新时间 2019-02-13 03:53:31 UTC
浏览: 9857   回复: 1
Tim Cox
更新时间 2019-02-02 01:35:59 UTC
浏览: 9769   回复: 3
Sangjin Lee
更新时间 2018-12-15 18:56:48 UTC
Thanks in advance!
浏览: 15573   回复: 1
