更新时间 2025-06-16 21:04:10 UTC
浏览: 7362   回复: 3
Error valve
becerril
更新时间 2025-06-10 19:45:14 UTC
浏览: 7385   回复: 1
Refurbished netro controller
drylake
更新时间 2025-05-23 23:37:47 UTC
浏览: 8506   回复: 1
Whisperer 2 temperature?
Brett Rabe
更新时间 2025-05-09 19:07:46 UTC
Thoughts?
浏览: 9021   回复: 1
Andrea DS
更新时间 2025-04-22 12:33:21 UTC
浏览: 8198   回复: 1
Smart Sprinkler Controlle starts then stops
Nigel Briggs
更新时间 2025-01-10 23:15:31 UTC
My controller operates but many times, rather than executing the time setting. It just cuts out?
I do have a sensor connected but I took it out of the ground to exclude wet soil feedback
I'm guessing there is a parameter forcing the stops?
Could anyone give me a direction where to look?
浏览: 9294   回复: 1
Sprite went offline
dkoford@gmail.com
更新时间 2024-12-18 02:30:29 UTC
浏览: 9252   回复: 1
Solenoid does not switch off
Nath Moyes
更新时间 2024-11-15 00:49:20 UTC
Nath
浏览: 8867   回复: 1
Netro Spark valve testing
Peter Strohmayer
更新时间 2024-11-14 13:49:20 UTC
Peter
浏览: 8725   回复: 1
Zone won't shut off.
shoo.shoo
更新时间 2024-11-10 05:55:43 UTC
浏览: 8755   回复: 1
BrettEnyart
更新时间 2024-10-13 18:02:06 UTC
浏览: 9069   回复: 2
12330barryknoll
更新时间 2024-10-10 01:51:03 UTC
浏览: 9157   回复: 1
cjulian
更新时间 2024-10-05 18:05:09 UTC
浏览: 8914   回复: 1
Zone 1 not watering
11807GFT
更新时间 2024-09-24 23:25:59 UTC
浏览: 7950   回复: 1
Thomas Murphy
更新时间 2024-09-18 12:39:46 UTC
Hello there!
Thank you so much!
浏览: 8083   回复: 1
Smart watering not working
更新时间 2024-09-10 16:17:51 UTC
浏览: 8116   回复: 1
Broken whisperer sensor
Jesús López
更新时间 2024-09-09 16:19:33 UTC
Hi everyone!
浏览: 8877   回复: 2
Discrepancia APP y WEB
JM del Amo
更新时间 2024-09-07 13:06:53 UTC
浏览: 8284   回复: 1
1 valve works, two don't
Phil Rubin
更新时间 2024-08-17 21:52:30 UTC
浏览: 8415   回复: 1
Zone watering while disabled
Brian Paternostro Paternostro
更新时间 2024-07-31 10:10:11 UTC
I am doing yard work to 2 of my 3 zones right now and have the whole system disabled for several days as many heads are disconnected.  Woke up a 5am to have zone 3 on and spraying water everywhere for 20 minutes.
How is this possible? Why do you not update your softwar?
浏览: 8765   回复: 2
