Karen Thompson
更新时间 2022-09-02 15:15:20 UTC
浏览: 8579   回复: 1
A Gallo
更新时间 2022-08-29 14:28:38 UTC
浏览: 8177   回复: 1
Clock on sprite
Rory
更新时间 2022-08-24 19:43:30 UTC
浏览: 7923   回复: 1
Sprinklers run repeatedly
Sunil Sivanand
更新时间 2022-08-12 01:18:11 UTC
浏览: 8047   回复: 1
Juan Brea
更新时间 2022-07-26 18:08:13 UTC
浏览: 8191   回复: 1
Repuesto
Juan Pascual
更新时间 2022-07-23 08:12:17 UTC
Buenos días desde España
Mil gracias
浏览: 9171   回复: 2
Zone won't shut off
chesh235
更新时间 2022-07-18 18:53:38 UTC
浏览: 8122   回复: 2
Plant sensor
Miro D
更新时间 2022-07-14 10:42:35 UTC
浏览: 8011   回复: 1
More data
Jim Shaffer
更新时间 2022-07-13 13:06:30 UTC
浏览: 8026   回复: 1
Android devices logout issue
Wency Pan
更新时间 2022-07-12 06:35:45 UTC
浏览: 12637   评论: 1
Pump Problem
wvfox
更新时间 2022-06-28 16:18:58 UTC
Vance
浏览: 7985   回复: 1
New Whisperer Issue
Alfonso Marin Salgueiro
更新时间 2022-06-24 15:15:07 UTC
Hello everyone from Spain.
Can somebody help me?
I attach a photo.
Thank you very much.
浏览: 8175   回复: 1
更新时间 2022-06-19 17:14:35 UTC
Added information:
浏览: 10388   回复: 4
end Battery life?
更新时间 2022-06-15 13:23:27 UTC
浏览: 8184   回复: 1
Tech support
Robert Dambrosio
更新时间 2022-06-13 00:41:59 UTC
浏览: 8791   回复: 1
Netro light
beppezhome
更新时间 2022-06-09 14:46:24 UTC
浏览: 8071   回复: 1
James Berg
更新时间 2022-06-05 01:03:46 UTC
浏览: 8658   回复: 1
Andy Ricco
更新时间 2022-05-31 06:12:27 UTC
浏览: 8681   回复: 1
Sleeping mode
Fabrice GOUFFRAN
更新时间 2022-05-18 10:11:40 UTC
浏览: 11990   评论: 1
water valve does not work
Paolo Raviolo
更新时间 2022-05-03 15:55:47 UTC
I set up the pixie timer, everithing seems ok but the valve does not opens, nor with program nor in manual mode, no water at all.
can you help me?
浏览: 7968   回复: 1
