Network Error with code: 3405
Stefan W.
更新时间 2023-05-27 20:05:45 UTC
Hi everyone. When I try to add another user in the app, I get the message „Network Error with code: 3405“
Any solution for this?
浏览: 8300   回复: 1
Zone invert
Stebel
更新时间 2023-05-28 04:42:47 UTC
浏览: 8091   回复: 2
Gestione ritardi
Stebel
更新时间 2023-05-28 04:44:07 UTC
浏览: 8122   回复: 1
Rename device
3 Dorset Lake Avenue
更新时间 2023-05-28 09:51:48 UTC
浏览: 7823   回复: 1
Custom sprinkler flow rate
Jure
更新时间 2023-06-01 14:42:27 UTC
浏览: 8270   回复: 1
WU PWS request pixie-Z1
Richard B
更新时间 2023-05-29 01:04:07 UTC
浏览: 7912   回复: 1
Controller location
Francesco Zorzetto
更新时间 2023-05-29 13:55:31 UTC
Hi, during the installation phase of the controller, it was not possible to change the position regarding the geographical state of the machine, a US state remains by default and consequently, I can assume, the start times of the irrigation cycles are carried out with the time zone american time. How can I fix it?
浏览: 8631   回复: 1
Arturo Camin
更新时间 2023-05-30 09:17:10 UTC
浏览: 8079   回复: 1
New grass from seed
D Berggren
更新时间 2023-05-31 01:11:58 UTC
浏览: 7945   回复: 1
Corinne Cleary
更新时间 2023-06-01 00:55:20 UTC
Please help.
浏览: 7995   回复: 1
kaitech
更新时间 2023-06-01 19:44:40 UTC
How can I troubleshoot it?
浏览: 7827   回复: 1
Smart mode initial watering
Matt Ward
更新时间 2023-06-02 01:19:52 UTC
浏览: 8450   回复: 1
Nero Sprite
Glenn Thurston
更新时间 2023-06-02 12:12:10 UTC
浏览: 7811   回复: 1
Power
nvenezia
更新时间 2023-06-02 18:10:49 UTC
浏览: 8714   回复: 1
D Hitch
更新时间 2023-06-03 14:10:58 UTC
Thanks for any help.
浏览: 7953   回复: 1
Börke Titscher
更新时间 2023-06-04 08:32:03 UTC
Folks
浏览: 8011   回复: 2
2 zones not working
Shahid Habib
更新时间 2023-06-05 13:39:04 UTC
Any help will be appreciated.
浏览: 8467   回复: 3
Adil Ridvan
更新时间 2023-06-08 04:44:28 UTC
Pros:
Cons:
Adil
浏览: 11131   回复: 1
Change Country
samhye
更新时间 2023-06-08 12:58:01 UTC
Hello all,
Many thanks.
浏览: 7996   回复: 1
Netro sprite chpset.
Eduardo Pariente
更新时间 2023-06-09 18:15:24 UTC
Hello everyone.
Thanks you.
浏览: 8089   回复: 1
