Franck FONTANEL
更新时间 2025-07-18 19:49:49 UTC
I don’t know why ?
浏览: 7322   回复: 1
Pause
Tamgar chan
更新时间 2025-07-19 10:59:15 UTC
浏览: 7617   回复: 1
Whisperer low battery alert
Jesus Sanguinetti
更新时间 2025-07-19 15:24:34 UTC
浏览: 7675   回复: 1
Stefano
更新时间 2025-07-21 21:17:23 UTC
Hi everyone,
I’ve already tried:
Thanks in advance!
– Stefano
浏览: 7781   回复: 1
Change zone order
Matt Ward
更新时间 2025-07-22 00:43:18 UTC
浏览: 7956   回复: 1
Andrew Woods
更新时间 2025-07-22 19:30:55 UTC
浏览: 5182   回复: 1
Interoperability with Alexa, Homey, any other smart home platform?
arnaud@brucy.org
更新时间 2025-08-22 19:03:11 UTC
Is there any interoperability/integration existing or planned with home automation/smart home platforms?
Integration with Homey Pro would be great, being able to fetch the watering status for each zone, start a manual watering, or send some external triggers (humidity, rain water tank level, etc.)
Thank you !
Arnaud
浏览: 6982   回复: 2
Password
Ignacio Sánchez
更新时间 2025-09-26 11:38:52 UTC
浏览: 5127   回复: 1
Whisperer installation
Davide Chelo
更新时间 2025-09-26 11:38:17 UTC
Hi, I just bought the whisperer 2 and would like to have it as only sensor for the entire garden, however is allowed to have maximum 3 zones for sensor. Is there a way to link all the zones to it? I have 7 zones.
浏览: 5023   回复: 1
I want to change wifi network my Netro controller is connected too.
loro
更新时间 2025-09-23 21:27:44 UTC
How do I change the wifi network my Netro controller is connected too? I cannot proceed beyond step 2 from the instructions on the app. I get the message "Please connect to Wi-fi network "Netro_IRC_xxx."  However, the app shows that I am already connected!!
浏览: 5543   回复: 1
Info function
Giuseppe
更新时间 2025-09-20 09:48:50 UTC
浏览: 5645   回复: 1
Program change Day
Tiziano Pacella
更新时间 2025-09-17 19:04:30 UTC
Someone can help me?I need change the day for one program exists...what is the procedure? Thak you
浏览: 5574   回复: 1
Rainbird esp me series
Magnus Swenson
更新时间 2025-09-15 14:38:33 UTC
Can I use the Netro Spark 16 if I use the Rainbird ESP Me? I have 15 active zones.
浏览: 5856   回复: 1
Time
Silvano Scotto
更新时间 2025-09-10 23:18:59 UTC
浏览: 6386   回复: 1
Centralina non funziona
gsciurba
更新时间 2025-09-09 19:23:32 UTC
Buongiorno,
  • la tensione in uscita è sempre di circa 11 V AC su tutte le uscite;
  • la centralina è stata utilizzata pochissimo, solo con le zone master e 1–2;
  • non sono presenti segni visibili di bruciatura o danni hardware.
Grazie per l’attenzione.
Cordiali saluti,
Giuseppe Sciurba
浏览: 6340   回复: 1
Netro spark no work
Fernando Bravo Calatayud
更新时间 2025-09-04 08:25:22 UTC
I've had a Netro Spark 8 working without any problems since last year, but a few days ago it disconnected from the Wi-Fi and stopped working. I tried the reset button as indicated in the instructions, but there's no way to reconnect it. What else can I do? Thank you very much
浏览: 6795   回复: 1
Francesco Gritti
更新时间 2025-08-29 16:39:06 UTC
浏览: 7053   回复: 1
更新时间 2025-08-24 22:55:28 UTC
浏览: 7297   回复: 1
Non riesco a connettere metro spring con metro wisperer
Fabio Doc
更新时间 2025-08-23 07:43:08 UTC
浏览: 7298   回复: 1
Interpretation of soil moisture readings by Whisperer
Missy Bartell
更新时间 2025-07-26 12:13:30 UTC
I have two Whisperers that I move around to various parts of my graden to get comparative readings of sunlight and soil moisture.  I really do not know how to interpret the moisture readings which generally range from 50% to 98% but can be as low as 30%.  Soil type varies from a clayey loam to heavy clay.   How do I know when watering is required?  Does the meter measure the capillary water?  The adhered water?  The percentage of voids filled with water?  How does Netro calculate the percentage of water and what do the readings mean?
浏览: 5510   回复: 1
