Days not appearing on 6-days a week schedule
Rec Tift
更新时间 2023-05-17 02:40:49 UTC
Our watering restrictions are on 6-days a week. Thursday, Friday, and Saturday do not show water schedule. How do I add these days to program?
浏览: 8010   回复: 1
Richard Nibbler
更新时间 2023-05-17 02:50:09 UTC
Tyvm
浏览: 8476   回复: 3
Problem in Netro app in my iPhone
Manel Barbero
更新时间 2023-05-18 08:21:17 UTC
I had installed an irrigation controller and one plant sensor and it worked OK. Since I have added one Pixie-1 and one Pixie-Z1, on the app screen when I try to enter innthe red ring bell to see notifications, I am thrown out the app and I can’t see my notifications.
浏览: 8340   回复: 1
Watering problem
Marco Nicosia
更新时间 2023-05-21 10:35:08 UTC
Does it happen to anyone that sometimes the irrigation starts by itself despite the program being set to manual?
浏览: 7714   回复: 1
App Showing Ofline
Katie Wallace
更新时间 2023-05-21 11:09:21 UTC
浏览: 7604   回复: 1
Mismatch zones/times
Jose R
更新时间 2023-05-21 12:40:53 UTC
So happy with how this works.
浏览: 7752   回复: 1
Strange watering cycle
Joe Mariano
更新时间 2023-05-22 14:40:16 UTC
浏览: 8076   回复: 1
Material
Georges Bouvier
更新时间 2023-05-23 07:32:12 UTC
Does Netro supply an equipment with 2 output
I need watering 2 different areas?
Thks
浏览: 10306   回复: 2
Cannot connect
Jerry Gadd
更新时间 2023-05-23 19:15:35 UTC
I am not able to successfully connect to my new pixie
1. Pixie lifht flashing white
2. Login to App
3. Add Product
4. Select device
5. Enter name and addess info
6. Begin
7. Connext phone to Netro wifi
8. Next
9. Select homw wifi
10. Enter password
11 next
... Connecting...
Pixie light flashes white, eventually turns red
App errors
Wifi password is correct, and i am in same room as router aand pixie is next to me.
How dobi check port is not beinf blocked hy router? I have Huaweu Q2 Pro, dont see anything tonsuggest iit is.
浏览: 10777   回复: 1
Frequently disconnection from the wifi
PaoloMassignan
更新时间 2023-05-24 05:07:48 UTC
My device is always offline unable to connect to the wifi. I have to reset it and then the connection works for a while.
There is a repeater  2 meters from it. The signal is strong.
浏览: 7858   回复: 1
Update the irrigation routine according to the updated weather forecast
Luis T
更新时间 2023-05-24 15:44:31 UTC
Hi there!
I live in Madrid, Spain and use AccuWeather as my weather provider, since NetroWeather does not provide a correct forecast for this area for some reason.
This week we have had heavy rain forecast so Netro will not activate the irrigation system for several days. The problem is that as the day goes by the forecast is changing and Netro's planning is not updated.
It has already been several days in which according to the initial forecast, it was supposed to rain and it did not, so I have had to launch manual irrigations.
Is there any way to force the smart irrigation program to update according to the new weather forecast?
浏览: 8729   回复: 1
Netro Spark firmware version
Luis T
更新时间 2023-05-24 15:54:35 UTC
I have a Netro Spark with firmware version 3.2.1. Firmware updates are done without user intervention or how can I perform a firmware update?
浏览: 8632   回复: 1
A Netro Spark with no WIFI
Lino
更新时间 2023-05-25 16:07:02 UTC
Just bought a Spark and realized my home wifi sig doesn’t reach the location where it is installed.
While I sort out how to increase the signal I wonder if there is a way to program the Spark to operate without Wifi
浏览: 7996   回复: 1
Rotor head
Sjors Janssen
更新时间 2023-05-25 19:15:07 UTC
I've just been using a Netro Spark to water my garden. I have set up 3 zones. Two of these zones have a rotor head sprinkler. However, they don't cover the same area. One of them rotates over 90 degrees. The other rotates 180 degrees. So I think the rotor head that covers the 180 degrees needs to run double the time of the 90 degree one. How can I set this? I've set the sqm for each head, but smart irrigation used the same times for both.
Kind regards,
Sjors
浏览: 7828   回复: 1
Zones
Lea Schneider
更新时间 2023-05-25 23:29:01 UTC
My zones 5-12 won’t work but my zones 1-4 are working fine .    Any ideas what to do ?
浏览: 7962   回复: 1
Manuel Run delay
BOBBY BROWNE
更新时间 2023-05-26 00:37:50 UTC
Why is it when I hit manual run? There’s always a delay.
浏览: 7922   回复: 1
Can I back up my Netro?
Jacob Matheny
更新时间 2023-05-26 15:39:51 UTC
浏览: 8119   回复: 0
Jacob Matheny
更新时间 2023-05-26 15:39:56 UTC
浏览: 8256   回复: 1
Unable to delete 6-zone control unit from PC
Luciani Daniele
更新时间 2023-05-27 09:26:29 UTC
This morning I had to reset the 6 zone control unit. After the reset everything is fine from the Netro app. Instead, when I log in from a PC with my account, the old setting is detected and it won't let me delete it. The system returns error nvalid group ID 33131: invalid device status.
What to do?
浏览: 8367   回复: 1
One channel is always on
Stefan W.
更新时间 2023-05-27 19:58:05 UTC
Hi everyone,
I have a 6-channel Sprite with 6 hunter valves. 5 channels work perfectly, one seems to be always on. I tried a brand new valve, a reset of the Sprite, unplugged it from power, changed the wiring but nothing helped. Any ideas?
Cheers, Stefan
浏览: 8111   回复: 3
