Green Peas
更新时间 2023-01-01 18:34:14 UTC
浏览: 8230   回复: 2
Home Assistant
Jens Wymeersch
更新时间 2023-01-12 09:25:04 UTC
浏览: 9576   回复: 2
Customized moisture level not triggering watering
Richard
更新时间 2023-01-12 21:29:59 UTC
I have a Sprite with 3 Whisperers, all in the veggie patch.
I have the zones set to customize with a low of 25% and a high of 45% (I find 30 - 35 % moisture about right)
But the zones just won't get watered!
Zone 1 is down to 6% today and has been dropping steadily for days.
I HAVE to manually water, as the day time temperatures are consistently over 30 degrees (today 33, tomorrow 37).
Otherwise the plants will die.
Given there are only two values to enter (low and high). How do I stop the Netro from skipping days and putting the zones in the "Moisture" category??
浏览: 9647   回复: 1
Change Username
Casa Luna
更新时间 2023-01-13 10:08:35 UTC
Is it possible?
Thanks in advance :)
浏览: 7571   回复: 1
Delay on Manual watering
Jim Barnes
更新时间 2023-01-22 01:22:58 UTC
Why is it when I select a manual watering it delays until wake up?
浏览: 8137   回复: 1
Reduce watering time in 1 zone
Ale Levi
更新时间 2023-01-22 19:32:59 UTC
Hi, I'd like to reduce the watering time in 1 zone which gets dumped each time Netro waters. The other zones are ok. Is there a way to do that in the smart mode? Maybe set an offset for that specific zone?
浏览: 7672   回复: 2
andrew58
更新时间 2023-01-25 08:49:48 UTC
浏览: 7641   回复: 1
Jim Barnes
更新时间 2023-01-25 13:36:55 UTC
Please help!!!
浏览: 8267   回复: 2
Whisperer plant sensor
Vincent Coutinho
更新时间 2023-01-26 20:56:14 UTC
How do you find the sensor battery percentage on the netro app.
浏览: 8386   回复: 1
Help
Vũ Trần
更新时间 2023-01-30 07:35:09 UTC
浏览: 9776   回复: 3
Whisperer light
更新时间 2023-02-01 09:56:18 UTC
What should I do ?
浏览: 8420   回复: 1
MEANING OF code E2
balvant patel
更新时间 2023-02-02 16:06:49 UTC
What is E2 means?
Pl. reply ASAP
Patel
浏览: 7989   回复: 1
Vanina Lesko
更新时间 2023-02-03 09:47:24 UTC
浏览: 8214   回复: 1
Smart schedules
Vincent Coutinho
更新时间 2023-02-07 20:51:01 UTC
浏览: 8360   回复: 1
Whispered sola panel deteriorated after 6 months
更新时间 2023-02-08 06:15:54 UTC
After 6 months of whispere’s exposed to sun, the protective layer of screen is started yo be deteriorated, losing the transparency property and protection to UV, meaning is catching up less sun.
Answer from Netro support after several exchanges had not been at the right level, despite that last topic was really well addressed.
“Thanks for your info and it should not affect the normal use of the sensor. Please let us know if you see any further issues during use.“
Check pictures and make your statement, but I am not convince about quality of manufacturing of the whispered elements.
David
浏览: 8468   回复: 1
Set watering days
Mel Culley
更新时间 2023-02-12 02:31:35 UTC
I am struggling to set up the watering days
There isn’t an option for 4 / 3 / 4 rostered days which is are allocation here in Perth Australia
Please advise
TIA 👍
浏览: 11109   回复: 2
Richard
更新时间 2023-02-17 06:29:52 UTC
Hi there.
Cheers.
浏览: 8566   回复: 2
Smart zone manual setup
Vieri Verze
更新时间 2023-02-18 08:31:43 UTC
I do not understand how many millimeters to set. I have microsprinklers of 4lt/h and 2lt/h. I thought to set to 4000ml/h but the max is 100ml/h.
How to calculate? I have a big terrace with 30 plants and various microsprinklers.
Vieri
浏览: 8342   回复: 2
Location Setting
ubo25
更新时间 2023-02-18 10:10:44 UTC
Please advise how I can change the location. I am staying in Windhoek, Namibia.
浏览: 7763   回复: 1
Notifications/Wunderground
Fernando AT
更新时间 2023-02-26 18:00:46 UTC
Hello!
1. How can I enable notifications (when watering, sensor moisture level…)?
2. Cannot set my Wunderground station ISANTA605.
浏览: 7928   回复: 1
