Hub with more than 1 timers
Kay Fluhr
更新时间 2023-10-08 07:46:18 UTC
Dear netro team
I solved the problem.
浏览: 8220   回复: 1
Zone failure to run
Homestead One
更新时间 2023-10-09 08:30:37 UTC
Hi, I have one out of 4 zones who won't start watering. I have changed the valve and the problem still persist. I have checked the connections and the cables, all looks good. There is voltage.
Any ideea?
浏览: 7489   回复: 1
Whisperer maintenance
Fabrice GOUFFRAN
更新时间 2023-10-11 02:34:36 UTC
浏览: 6938   回复: 1
Sprite 12 Controller Problem
John LaRocca
更新时间 2023-10-14 01:42:23 UTC
浏览: 8065   回复: 1
Terrible product?
Andrew Martin
更新时间 2023-10-16 14:26:31 UTC
Three hours to setup
浏览: 8432   回复: 2
