Kay Fluhr
更新时间 2023-08-11 17:07:54 UTC
Hi there
浏览: 8190   回复: 2
Pixie
Charles Schatz
更新时间 2023-08-12 15:53:10 UTC
How do I synch my pixie without having to wait for the scheduled time?
浏览: 8164   回复: 1
Louise Brinkman
更新时间 2023-08-12 23:01:10 UTC
浏览: 8468   回复: 1
C He
更新时间 2023-08-13 11:54:36 UTC
Whats wrong?
浏览: 8651   回复: 1
Aspensprinklers
更新时间 2023-08-13 23:37:32 UTC
浏览: 8181   回复: 1
Moisture to skip watering
Maurizio Gianesin
更新时间 2023-08-15 19:55:07 UTC
I appreciate any answer .
Many thanks
浏览: 8116   回复: 1
C He
更新时间 2023-08-17 05:23:52 UTC
Hello Netro Support,
What’s wrong?
浏览: 8442   回复: 2
Jacob Matheny
更新时间 2023-08-22 15:14:09 UTC
浏览: 8566   回复: 0
Jacob Matheny
更新时间 2023-08-22 15:15:10 UTC
浏览: 8579   回复: 1
TJ Wasik
更新时间 2023-08-23 18:57:57 UTC
浏览: 8078   回复: 1
Xavi
更新时间 2023-08-25 21:23:22 UTC
浏览: 7968   回复: 0
Not connecting
Ali M
更新时间 2023-08-27 05:07:14 UTC
浏览: 8130   回复: 1
Addind more than 3 Users?
scgrossengersdorf
更新时间 2023-08-27 11:07:02 UTC
Hello everyone,
WH
浏览: 8082   回复: 1
Sensor offline
Tonycimo
更新时间 2023-08-28 21:29:20 UTC
How csn i solve it?
Czn i check snything?
浏览: 8121   回复: 1
Scott Yates
更新时间 2023-08-29 12:38:49 UTC
浏览: 8769   回复: 1
Leandro
更新时间 2023-08-31 10:48:12 UTC
HI Support Team and All,
This wasn't written anywhere.
thank you all
Leandro
浏览: 8365   回复: 2
Jacob Matheny
更新时间 2023-09-01 13:44:37 UTC
浏览: 8900   回复: 1
C He
更新时间 2023-09-04 06:22:44 UTC
This is smart watering?
浏览: 8648   回复: 1
smart watering
Diane Fetherolf
更新时间 2023-09-04 22:29:30 UTC
浏览: 8113   回复: 1
Parallel Run of watering
C He
更新时间 2023-09-08 08:39:13 UTC
Hallo and short question:
浏览: 8813   回复: 2
