Arghhh, so horrible
Jake Tanner
更新时间 2023-09-09 16:24:29 UTC
浏览: 8285   回复: 1
Whisperer stake cracked
更新时间 2023-09-09 20:22:46 UTC
浏览: 8853   回复: 1
Soil moisture adjustment
更新时间 2023-09-12 01:34:23 UTC
浏览: 8891   回复: 1
Scheduling Issue
Steve Loesch
更新时间 2023-09-12 13:59:31 UTC
First.
Second.
浏览: 8407   回复: 1
Change Wifi problem
Luciani Daniele
更新时间 2023-09-12 15:54:28 UTC
浏览: 8199   回复: 1
smart zone advanced range
Leandro
更新时间 2023-09-12 17:37:36 UTC
Thanks for the reply
Leandro
浏览: 8250   回复: 1
David Solis
更新时间 2023-09-14 21:05:39 UTC
Thank you in advance
David
浏览: 8737   回复: 2
My device is offline
carlos davalos melgar
更新时间 2023-09-17 18:50:32 UTC
i
How can I reconnect to Wi-Fi
the controller light is green
Please i need help
浏览: 8788   回复: 1
Copy setting to new spark device
John Wright
更新时间 2023-09-17 19:57:29 UTC
My original netro spark died and I have received a new one.  Is there a way to copy the zone settings from the old to the new
浏览: 10906   回复: 1
Stephen CC
更新时间 2023-09-19 08:44:03 UTC
浏览: 8297   回复: 1
Unrequested watering cycle
Claudio Polacco
更新时间 2023-09-23 07:00:27 UTC
Hello everybody, maybe someone can help.
This morning I found the irrigation system on, watering the garden, with no schedule active. More, the master enable/disable switch on the app homepage was set to off.
I'm using manual zone scheduling, not smart watering.
The controller is a Netro Sprite 6 zones, Wifi was on and fully functional.
Any ideas? Thanks.
Claudio
浏览: 8500   回复: 1
Horario
Conchi Herrero
更新时间 2023-09-27 13:00:48 UTC
Gracias.
浏览: 8262   回复: 1
Schedule
Jim Lacy
更新时间 2023-09-28 02:00:48 UTC
浏览: 8632   回复: 1
kamiller42
更新时间 2023-09-29 15:44:58 UTC
浏览: 8144   回复: 1
Whisperer 2 "serial already in used" issue
pridebowl33
更新时间 2023-09-29 16:07:36 UTC
I have been trying to add back one of my Whisperer 2 sensor and got a message saying that the serial has been already in used. Not sure what to do at this point. I was wondering if someone had encountered the same issue and if there is a solution to fix it.
Kevin
浏览: 8430   回复: 1
Phil Middleton
更新时间 2023-09-30 12:48:53 UTC
Kind regards
Phil
浏览: 8787   回复: 1
2 zonas funcionando a la vez?
Juan Carlos
更新时间 2023-09-30 18:53:13 UTC
浏览: 8642   回复: 1
Zone Failure
Ben Pittarelli
更新时间 2023-10-03 12:31:07 UTC
I have the Sprite 12 controller with zone 3 failing to work after 10 months.  Traced error to low voltage on controller. Anyone else having zone failures caused by controller?
Moved wire to unused zone 12 and sprinklers engage as they should.
浏览: 8479   回复: 1
Linking Google Home to Netro
cadry1969
更新时间 2023-10-07 03:21:23 UTC
浏览: 8383   回复: 2
Yellow exclamation mark
MyGowdy
更新时间 2023-10-07 23:05:24 UTC
浏览: 8401   回复: 1
