Netro sprite chpset.
Eduardo Pariente
更新时间 2023-06-09 18:15:34 UTC
Hello everyone.
Thanks you.
浏览: 7996   回复: 0
Whisperer sensor
更新时间 2023-06-10 17:39:10 UTC
浏览: 8810   回复: 1
更新时间 2023-06-10 17:50:24 UTC
浏览: 8412   回复: 1
Srdjan
更新时间 2023-06-11 05:21:33 UTC
浏览: 8230   回复: 2
Problem with APP connection
Davide G.
更新时间 2023-06-11 05:49:55 UTC
浏览: 8274   回复: 2
Certificate error
ventinovesette
更新时间 2023-06-11 06:03:25 UTC
浏览: 8381   回复: 2
Certificate Expired - AGAIN!
AllenHome
更新时间 2023-06-11 06:42:24 UTC
浏览: 7843   回复: 1
Netro sprite
mekanicul Meku
更新时间 2023-06-11 09:43:07 UTC
浏览: 8285   回复: 1
Apollon16
更新时间 2023-06-12 12:25:08 UTC
Apollon16
浏览: 10775   回复: 1
Beau Cook
更新时间 2023-06-12 23:10:58 UTC
浏览: 8101   回复: 1
Delay settings
Roberto Pirovano
更新时间 2023-06-13 09:15:35 UTC
浏览: 8164   回复: 1
Calibrating sprinkler output
SonDeMar
更新时间 2023-06-13 15:16:54 UTC
浏览: 8100   回复: 1
No notifications
Khalid Mousa
更新时间 2023-06-14 03:25:18 UTC
浏览: 8517   回复: 1
Pixie-Z1-H - How to install?
kernel
更新时间 2023-06-14 15:54:05 UTC
  • I have received a new Pixie-Z1 and a hub
  • Downloaded the Netro iOS App from the UK app store
  • In the App I added the hub connecting through Bluetooth and configuring WiFi access for the hub
  • Hub shows constant green light
Now how can I add the Pixie-Z1 hose faucet to my account? The App only shows the option for the Pixie-1, which doesn't work because the Pixie-Z1 uses the Zigbee connection, not WiFi.
浏览: 11104   回复: 1
zoe
更新时间 2023-06-15 00:40:38 UTC
Linda Lundgren
浏览: 8046   回复: 1
Rainy day shut off
更新时间 2023-06-16 13:18:25 UTC
浏览: 8699   回复: 1
Zone doesn't stay on
Brent S
更新时间 2023-06-18 02:05:28 UTC
Hi just installed a sprite 6. I can here zone turn on then immediately turns off but the timer is still running on the app. I can hear the water stop and start in each zone ; the app thinks it's watering but the valve closes. Same for all zones
Thansk
浏览: 8279   回复: 1
Luis T
更新时间 2023-06-18 15:30:17 UTC
Any comments are welcome.
浏览: 11193   回复: 3
更新时间 2023-06-19 09:25:40 UTC
浏览: 8605   回复: 2
Disconnessione
Carlo Capraro
更新时间 2023-06-19 12:11:17 UTC
Grazie a tutti
浏览: 7895   回复: 1
