Maximum watering duration for SPARK
Katarzyna Wrobel
更新时间 2023-04-11 22:55:50 UTC
Hi there :)
I want to set-up a watering duration for my desert garden (Phoenix, AZ). We should water our garden deeply and infrequently. So, I want to set-up a watering time of two hours. Unfortunately, the app has a maximum duration set to 60 minutes only. Any suggestions?
浏览: 7678   回复: 1
Whisper will not factory reset!
Ross Brown
更新时间 2023-04-13 10:43:03 UTC
Hi I have had to send back my spark due to a problem with one zone not operating, I’m now trying to do a reset on my whisper, I have pressed the power button quickly 6 times, on numerous occasions and cannot get it to reset, any help would be much appreciated. New Spark arrived and working well, l just can’t seem to reset the Whisper no matter how many times I try the on/off 3 times. Are there any other action I could do or do I return it for a replacement?
浏览: 10059   回复: 1
Suggestions and Question.
Maurizio Gianesin
更新时间 2023-04-12 15:08:32 UTC
Good morning.
I just started using Netro Sprite 8 zones out of 12 zones with two whisperers.
Congratulations for the App and the Web interface I'm using.
I have a concern about some trivial errors in the interfaces:
If you go to settings/preferences/SchedulingSetting
1.1 The Italian translation of "Two Frames" in "Due Cornici" makes me smile, it is better translated in "Due Cicli" or "Due Fasi". But my suggestion is also for English : it is my opinion that if instead of "Time Frames" and "Two Frames" you use "Time Phase" and "Two Phase" it is much better also for English and automatic translations free from misunderstandings.
1.2 Only in the App and not on the Web, the description of the two phases has "afternoon" under "morning" and vice versa.
Now I have a question:
I ask you for an explanation on Smart Scheduling.
I had set a lower limit of 10 C° and a Time Phase of 6:00 - 10:00. When I removed the 10 C° limit, the system did the same day a cycle at 23:58 instead of waiting for 6:00. why?
I hope I have been helpful and thank you for any response.
浏览: 7890   回复: 1
Wasteful
David Maerzke
更新时间 2023-04-13 13:19:47 UTC
浏览: 7802   回复: 1
carlos davalos melgar
更新时间 2023-04-13 20:06:46 UTC
浏览: 8131   回复: 0
更新时间 2023-04-13 20:06:57 UTC
浏览: 10638   回复: 0
更新时间 2023-04-13 20:07:05 UTC
浏览: 10425   回复: 1
Matt Ward
更新时间 2023-04-14 13:57:11 UTC
Matt
浏览: 8493   回复: 3
Intelligent mode useless
Juan Lambea
更新时间 2023-04-14 15:51:37 UTC
浏览: 11009   回复: 1
dummy serial for testing
更新时间 2023-04-16 17:53:00 UTC
浏览: 8394   回复: 1
Multiple users
Norm Markworth
更新时间 2023-04-17 00:22:59 UTC
Norm
浏览: 8973   回复: 2
Pixie keeps disconnecting
Sang Peiris
更新时间 2023-04-18 12:44:42 UTC
浏览: 8051   回复: 1
Add user Error
更新时间 2023-04-21 09:26:43 UTC
浏览: 7673   回复: 2
farenheit to celsius
Santiago Moller
更新时间 2023-04-22 02:41:55 UTC
Hello, I need help to change the settings from Fahrenheit to Celsius in the app, I have a smart plant sensor.  Thank you
浏览: 8652   回复: 1
Area
Javier Domínguez
更新时间 2023-04-22 16:04:10 UTC
Hola,
Cuando estoy configurando las zonas me pide un valor de area, ¿en qué medida? ¿Metros cuadrados?
浏览: 8114   回复: 1
valves under relay
Alek
更新时间 2023-04-22 17:48:29 UTC
浏览: 10276   回复: 1
Master error “open circuit”
Neil Lucey
更新时间 2023-04-24 14:09:12 UTC
Neil
浏览: 7869   回复: 1
更新时间 2023-04-24 14:27:08 UTC
Sprite / app
Never before
Disconnection to wifi
Even when say : online
irrigation )
浏览: 8446   回复: 1
Jim
更新时间 2023-04-24 17:38:25 UTC
浏览: 8224   回复: 2
Katie Woggins
更新时间 2023-04-24 18:40:07 UTC
浏览: 7748   回复: 1
