Scheduled for March watering says next watering April
Texas AF
更新时间 2023-03-03 14:31:32 UTC
This is so damn frustrating to use.
I set to water every odd day.  Start in March.  It’s March 3rd no watering being done and the app says next watering April.
Any suggestions?   Been struggling with this app for two years now about to give up
浏览: 7910   回复: 1
Shedule
jmgrau
更新时间 2023-03-09 07:21:43 UTC
How can I program the app so that it does not do automatic shedule watering, only those programmed manually, I only want the gespa dalt and gespa baix dryers to irrigate 1 minute a day.
浏览: 7893   回复: 1
更新时间 2023-03-15 08:50:34 UTC
浏览: 8315   回复: 1
Feature request
更新时间 2023-03-15 12:51:04 UTC
浏览: 8499   回复: 2
Whisperer is suddenly crazy
JM del Amo
更新时间 2023-03-15 15:39:31 UTC
After a lot of time working fine, suddenly whisperer is crazy. With no reason suddenly the humidity is at "0" and the temperatures are above "90". I have cleaned with water the whispers. I have cleaned the device with water but remains doing same random mistake-
浏览: 8007   回复: 1
Is Netro that smart?
Alessandro Alfei
更新时间 2023-03-16 00:53:44 UTC
why if Netro is so smart after months of learning with the whisperer still uses the "humidity to add watering" data set by me and doesn't create a custom program?  smartzone is in advanced level and regular mode.
浏览: 8512   回复: 2
Carlo Drago
更新时间 2023-03-18 18:55:41 UTC
Waiting your kind reply
Carlo
浏览: 8210   回复: 1
cannot connect my pixie to mi wifi with unifi Access point
christophe Minery
更新时间 2023-03-24 18:42:53 UTC
Someone can help me to connect to my unifi Wifi tm sensor Pixie ?
All goes OK unitl last step.... when it tell me that I connect connect to it
thanks
浏览: 8606   回复: 1
Dont't start manual irrigation
Simone Teressi
更新时间 2023-03-26 11:39:57 UTC
I've checked that My netro isonline...but if i start a manual irrogation app say to me "communicating" and never begin to start..... If i turn off elecrticity and turn on again..... And then i go to manual  Irrogation and press start irrogation begin immediatly
浏览: 7945   回复: 1
No 24V output?
Bigolin Davide
更新时间 2023-03-26 16:15:24 UTC
What can I do?
浏览: 7729   回复: 1
No wifi connection
gdimofte@gmail.com
更新时间 2023-03-27 18:00:53 UTC
Dear Sir
Gabriel
浏览: 7718   回复: 1
Sprinklers not going off per schedule
Brian Brun
更新时间 2023-03-28 22:50:06 UTC
What are my sprinklers not going off per schedule? I have a schedule that it supposed to kick off Tuesday and Thursday. It is set to start at 6:00. It is 6:50 and it has not went off. I just had to manually run a cycle.
浏览: 8262   回复: 1
Vincent Pollinzi
更新时间 2023-03-30 22:43:53 UTC
浏览: 7669   回复: 1
Michael Cayless
更新时间 2023-04-02 21:21:01 UTC
浏览: 8158   回复: 1
Phone number
Graham Corrett
更新时间 2023-04-05 13:07:22 UTC
Does anyone I have a contact/help number for this company possibly in the UK I’ve sent an email but no response!
浏览: 8065   回复: 1
Netro Sprite + Netro Pixie Z1
xergyo
更新时间 2023-04-10 09:58:51 UTC
Is it possible to connect the Netro Pixie Z1 to the wifi and to the App using the Netro Sprite without the need for the Netro Hub?
浏览: 10388   回复: 1
Pixie linked to 2 iphone
Paolo S
更新时间 2023-04-10 13:29:30 UTC
Is it possible to control 1pixie with 2 iphone?
浏览: 8327   回复: 1
更新时间 2023-04-10 15:17:46 UTC
Hi there
- seed type
- watering adjustement - EPA
- how tall to cut the grass
浏览: 8463   回复: 1
Abraio
更新时间 2023-04-10 17:53:48 UTC
浏览: 7714   回复: 1
Wiring multiple controllers
John Wright
更新时间 2023-04-10 19:05:31 UTC
I have an existing 18 zones irrigation controller which I am replacing. I require 2 controllers. No master valve or pump.
It is possible to connect both commons to the existing common connected to the 18 zones?
浏览: 10420   回复: 1
