Error in watering ?
Davide M.
更新时间 2022-08-29 11:31:56 UTC
Please help me:
  1.  what should I trust ?
APP:
WEB:
浏览: 8686   回复: 1
A Gallo
更新时间 2022-08-29 14:28:38 UTC
浏览: 8262   回复: 1
IFTTT out of sync
更新时间 2022-08-30 07:08:46 UTC
Please advise.
浏览: 8914   回复: 2
Program
Bob Neal
更新时间 2022-08-31 17:11:55 UTC
浏览: 6820   回复: 1
Random sprinklers turn on
Brian Strickler
更新时间 2022-09-01 12:33:12 UTC
浏览: 7326   回复: 2
Help! Pump Relay Question
更新时间 2022-09-01 13:43:25 UTC
My unit has been working great . However, the relay no longer trips when a zone is activated. Am I supposed to have 24v A/C between M and C (on the right side of the panel, not the zone side) when a zone is active? I can trip the relay if I pull it from the Netro. Some sort of voltage output map would be helpful.
I have new grass seed down, so please help soon.
浏览: 10083   回复: 1
How many rain sensors?
Roland Pircher
更新时间 2022-09-01 17:53:32 UTC
浏览: 7975   回复: 1
Two zones running at the same time
Jesse Sanchez
更新时间 2022-09-02 03:52:13 UTC
Anyone running into an issue of having two zones run at the same time when doing a manual run?
浏览: 8079   回复: 1
Karen Thompson
更新时间 2022-09-02 15:15:20 UTC
浏览: 8666   回复: 1
更新时间 2022-09-05 21:41:34 UTC
KVACHEST132
浏览: 7533   回复: 1
更新时间 2022-09-07 05:47:06 UTC
May you check it?
浏览: 7597   回复: 1
更新时间 2022-09-07 21:08:59 UTC
浏览: 8630   回复: 1
更新时间 2022-09-10 12:26:33 UTC
浏览: 8770   回复: 1
Add a manager
Tom Warren
更新时间 2022-09-10 16:36:08 UTC
浏览: 8173   回复: 2
Cannot reset Sprite
punyelroo
更新时间 2022-09-10 22:30:01 UTC
How do I fix this ?
-A
浏览: 8485   回复: 1
quick stop every watering
Lee Hill
更新时间 2022-09-11 20:34:04 UTC
浏览: 7224   回复: 1
Mulch impact on duration
John Wright
更新时间 2022-09-13 12:58:29 UTC
浏览: 8255   回复: 1
Different symbols in the app
Leon Durning
更新时间 2022-09-13 16:05:13 UTC
What does the ! mean?
浏览: 8264   回复: 1
Not watering
jons
更新时间 2022-09-16 09:37:00 UTC
It shows watering, but it is not?
浏览: 8096   回复: 1
Fernando Cantu
更新时间 2022-09-19 03:37:26 UTC
浏览: 9200   回复: 2
