Watering during a restriction
Valeria Dp
更新时间 2022-09-20 20:26:21 UTC
Tonight at 2.30 my netro start to watering. I had to stop it starting a manual program and stop it because in the app there was no watering sign.
Then I put a restriction for 3 days and around noon netro starts to watering again. There was a lost wifi signal for a minute cause by a voltage drop.
Is it normal?
浏览: 8507   回复: 1
Ananth
更新时间 2022-09-21 12:25:49 UTC
 How do i change this?
lot of water being wasted.
Ananth Bandla
浏览: 8331   回复: 2
Sprite-6
Rockhead413
更新时间 2022-09-26 18:04:30 UTC
Vincent Devlahovich
浏览: 8641   回复: 1
Irrigation program,
Rosario Russo
更新时间 2022-09-27 10:58:58 UTC
Rosario
浏览: 8314   回复: 1
Rosario Russo
更新时间 2022-09-27 11:06:57 UTC
浏览: 7072   回复: 1
Rick Miller
更新时间 2022-09-29 23:49:53 UTC
浏览: 7103   回复: 1
Veronica Slaughter
更新时间 2022-10-01 05:11:02 UTC
Any insight is so welcome!
浏览: 7217   回复: 1
Discover and weather accuracy
Geron R
更新时间 2022-10-01 12:38:37 UTC
浏览: 7393   回复: 1
No connection to WiFi.
Gianluca De Virgilio
更新时间 2022-10-02 21:48:54 UTC
Good afternoon.
浏览: 8305   回复: 2
Main feeder line shutoff valve control
Richard Miles
更新时间 2022-10-10 02:16:36 UTC
My main water line to the sprinkler system came loose and flooded my vacation home yard with 250,000 gallons of water before the leak was discovered and repaired.  Does Netro have the ability to control an electric valve on this feeder line such that the main valve will only open when the irrigation system calls for water?
浏览: 8462   回复: 1
Weather station
更新时间 2022-10-14 02:07:16 UTC
浏览: 7853   回复: 1
Water pressure
Omer Zadikevitch
更新时间 2022-10-18 18:15:38 UTC
浏览: 7066   回复: 1
更新时间 2022-10-20 14:57:19 UTC
Thanks for your advice
浏览: 7371   回复: 1
Water valve opened
Paolo Talamelli
更新时间 2022-10-23 10:52:29 UTC
浏览: 8276   回复: 1
Cutrone
更新时间 2022-10-25 17:06:24 UTC
Hello all!
浏览: 8225   回复: 2
Daniel Gajardo
更新时间 2022-10-27 01:22:57 UTC
浏览: 7487   回复: 1
Percentage Adjustment
jeremyagrelius@gmail.com
更新时间 2022-10-29 18:31:12 UTC
浏览: 6907   回复: 1
LearNetro Whisperer
更新时间 2022-10-30 19:15:38 UTC
At the end of the whisperer's learning time, the times are set automatically in the program or have to be done manually?
浏览: 9480   回复: 2
Gianluca Bus
更新时间 2022-11-03 12:03:59 UTC
Hi all!
Netro App vesion: 3.1.0
Netro controller hw ver.: 1.2
Thanks in advance.
Gianluca
浏览: 8312   回复: 1
Carlo Drago
更新时间 2022-11-04 18:48:50 UTC
Carlo
浏览: 8595   回复: 1
