更新时间 2023-07-24 00:54:03 UTC
浏览: 8696   回复: 1
misterhoff
更新时间 2023-07-25 03:11:25 UTC
浏览: 7881   回复: 0
Feature request update
更新时间 2023-07-25 06:11:19 UTC
浏览: 8509   回复: 1
Netro - Stopped Working and won’t power up
John Loethen
更新时间 2023-07-25 14:04:38 UTC
Been a Netro customer for a while and pretty handy. I have three different Netro controllers and my oldest one just stopped working and won’t power up… I have verified the power at the outlet and have changed out the power supply with another 24v power supply that I know works. Still the controller will not power up.
Let me know if anyone else has suggestions.
John in Lincoln, NE
浏览: 8075   回复: 1
Netro Sprite 6 valve won’t stop
Alberto Casu
更新时间 2023-07-29 19:25:45 UTC
I just replaced my sprinkler controller with a new Netro Sprite 6.
Using both a programmed or a manual start, all valves don’t stop unless I remove power to the Sprite.
During a program, where I planned the zones to run sequentially, the zones activate one after the other without stopping and causing the zones to loose pressure and be unable to complete.
On the FAQ, it says to remove power to stop the zone, which actually stop all the watering, but this it totally unusable to me.
I am using the European version with the provided power supplier. I am based in Italy.
Can you please help?
浏览: 8669   回复: 2
Netro phone app won't open
Christopher Scarborough
更新时间 2023-07-30 23:32:37 UTC
浏览: 7996   回复: 1
Tim Quach
更新时间 2023-08-01 08:02:49 UTC
浏览: 7976   回复: 1
Atif Siddiqui
更新时间 2023-08-02 04:51:58 UTC
浏览: 7975   回复: 1
Using Bootlace ferrules.
Bob Howard
更新时间 2023-08-03 06:36:09 UTC
I'd like to use bootlace ferrules for all the wiring to the sprite as shown in your installation video (power connection). I'm using 0.5mm² x 7 core cable and 0.5mm² bootlaces and the unit won't grip them. I've tried other sizes with the same result. What size ferrule is required?
浏览: 10632   回复: 1
Date format
Bob Howard
更新时间 2023-08-03 23:27:42 UTC
浏览: 8655   回复: 1
David H
更新时间 2023-08-04 17:15:09 UTC
浏览: 8192   回复: 1
App show’s pending message
Greg Jones
更新时间 2023-08-07 18:46:13 UTC
浏览: 8384   回复: 1
Drew M
更新时间 2023-08-08 17:48:40 UTC
浏览: 7901   回复: 1
We had 4 inches of rain
更新时间 2023-08-09 03:08:18 UTC
浏览: 8527   回复: 2
Cambio wifi
jmgrau
更新时间 2023-08-09 15:10:03 UTC
Espero su ayuda.
浏览: 7925   回复: 1
App is not installing
Martin Trevino
更新时间 2023-08-09 16:40:50 UTC
浏览: 7977   回复: 1
Louise Brinkman
更新时间 2023-08-10 05:52:23 UTC
浏览: 8568   回复: 1
Spark and Sensors
C He
更新时间 2023-08-10 06:45:57 UTC
Hi all,
Thanks for support!
浏览: 8311   回复: 1
Calendar View
更新时间 2023-08-10 11:23:26 UTC
Netro Support Team,
Houston, Texas
浏览: 8377   回复: 1
technic support
Isabel Santillan
更新时间 2023-08-11 07:07:33 UTC
浏览: 7844   回复: 1
