Plant needs
Bob Benny
更新时间 2025-06-19 00:30:05 UTC
Thank you for your help.
浏览: 6435   回复: 1
更新时间 2025-06-18 03:59:06 UTC
浏览: 6794   回复: 1
更新时间 2025-06-16 21:04:10 UTC
浏览: 7373   回复: 3
Lorenzo Bigagli
更新时间 2025-06-14 12:02:48 UTC
Please
浏览: 6084   回复: 1
Angelo Suppa
更新时间 2025-06-11 16:54:13 UTC
浏览: 8099   回复: 2
Error valve
becerril
更新时间 2025-06-10 19:45:14 UTC
浏览: 7396   回复: 1
Alessandro Mason
更新时间 2025-06-09 22:08:10 UTC
浏览: 6331   回复: 1
Ciccio Pasticcio
更新时间 2025-06-09 06:53:42 UTC
浏览: 7368   回复: 1
Bart Abbott
更新时间 2025-06-07 12:43:42 UTC
浏览: 6348   回复: 1
Indicator led is burn out
yigal
更新时间 2025-06-07 12:18:46 UTC
浏览: 6352   回复: 1
How do I change schedule
George S
更新时间 2025-05-27 21:37:14 UTC
浏览: 7805   回复: 1
overwatering
更新时间 2025-05-20 12:55:43 UTC
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
浏览: 9114   回复: 2
Refurbished netro controller
drylake
更新时间 2025-05-23 23:37:47 UTC
浏览: 8525   回复: 1
Battery Issue - Netro Stream
K L
更新时间 2025-05-25 03:09:56 UTC
Dear Fellows,
Device Details:
  • Hardware : Netro Stream 1.0
  • Firmware: 1.0.0
Best regards,
Kelvin
浏览: 9463   回复: 1
Mikael Hammarin
更新时间 2025-05-26 17:18:52 UTC
Suggestion:
浏览: 9048   回复: 1
New Sprite Owner
Bryant Bustamante
更新时间 2025-05-26 22:46:01 UTC
浏览: 9569   回复: 1
Alexa with two Pizie
Stefano Giorgi
更新时间 2025-06-03 16:11:11 UTC
How can I fix this issue?
浏览: 7806   回复: 1
Contrôler problem
Alain Turcotte
更新时间 2025-06-06 09:41:00 UTC
浏览: 7554   回复: 2
Dropped wifi (2.4 Gz)
C Hill
更新时间 2025-06-06 02:10:45 UTC
浏览: 6487   回复: 1
更新时间 2025-10-08 13:12:52 UTC
浏览: 4460   回复: 2
