Zone flexibility
Mike R
更新时间 2025-10-29 01:20:50 UTC
I have a hill that was terraced and replanted. I was told to run the circuit twice a day for 15 minutes for a month. Drip lines. Seems like my system doesn’t have that flexibility. Am i correct?
浏览: 4338   回复: 1
API broken?
Tortfeaser
更新时间 2025-11-21 04:58:13 UTC
Hi, I can get my Netro controller info using:
curl -v https://api.netrohome.com/npa/v2/info.json?key=MYAPIKEY
(where MYAPIKEY is a key from the user account page)
but when I try to update soil moisture data with:
curl -X POST -H "Accept: application/json" -H 'Content-Type:application/json' -d '{"key":"MYAPIKEY","moisture":100}' "https://api.netrohome.com/npa/v2/set_moisture.json"
I get an error about an invalid key:
{"status":"ERROR","meta":{"time":"2025-11-21T04:54:56","tid":"1763700896_KpmY","version":"2.0","token_limit":0,"token_remaining":0,"last_active":"2025-11-21T04:54:56","token_reset":"2025-11-22T00:00:00"},"errors":[{"code":1,"message":"Invalid key: ","params":{}}]}
What's going on?
浏览: 16317   回复: 1
Cannot add pixie z1
John R
更新时间 2025-12-09 02:23:46 UTC
I cannot add my pixie z1 to the app because pixie z1 is not shown as an option. I have the hub connected.
浏览: 4111   回复: 1
Watering on wrong day
keller3987
更新时间 2025-12-09 15:39:44 UTC
I have programmed my Netro to skip Tuesday’s but the controller waters anyway. How do I stop this?
浏览: 3947   回复: 1
The average temperature for a day is insufficient to calculate correct watering.
Richard
更新时间 2025-12-17 07:17:57 UTC
When I have Whisperers, the system appears to calculate the average over the day about 4 degrees higher than for zones without Whisperers.
It seems that, even though the weather data is available throughout the day, that zones without sensors only use the forecast high and low.
This is insufficient to correctly adjust for the amount of watering required.
For example, today is 7 degrees C up to 36.
Whisperer zones average the temp at 26C while non-Whisperer zone calculate the average at 22C.
On these extremely hot days, the non-whisperer zones are under-watering much more than the Whisperer zones.
Also note that even the zones with Whisperers always under-water and needs custom programs or manual intervention.
This finally explains to me why zones are always under-watered.
Can the system please use multiple day readings for non-Whisperer zones and PLEASE provide more watering?
浏览: 3975   回复: 2
Eric Jonsson
更新时间 2026-01-08 12:02:58 UTC
浏览: 3941   回复: 1
Shane V
更新时间 2026-01-19 04:54:45 UTC
浏览: 3785   回复: 1
Old whisperer
更新时间 2026-01-20 10:38:33 UTC
Seems a communication problem
浏览: 3686   回复: 1
Tuan Phan
更新时间 2026-01-25 18:28:34 UTC
浏览: 3549   回复: 1
Will
更新时间 2026-01-27 03:13:26 UTC
浏览: 3738   回复: 1
cpline
更新时间 2026-02-02 17:04:38 UTC
浏览: 3731   回复: 1
Notification
Alexis Demosthenous
更新时间 2026-02-05 19:28:19 UTC
浏览: 3775   回复: 1
Will
更新时间 2026-03-17 21:54:57 UTC
浏览: 4434   回复: 3
Sensor to zone
Mark Zeck
更新时间 2026-02-05 23:17:03 UTC
How do I connect my sensors to zones? I have the latest.
浏览: 3809   回复: 1
Feature Request
John Sirois
更新时间 2026-02-10 05:56:14 UTC
John
浏览: 3590   回复: 1
Supported Hardware
Colin Brierley
更新时间 2026-02-12 06:13:48 UTC
浏览: 4073   回复: 1
Support email- No reply
更新时间 2026-02-21 16:06:19 UTC
浏览: 3882   回复: 2
RKR Home
更新时间 2026-03-03 03:32:35 UTC
浏览: 3718   回复: 1
programs - reordering
Lee Hill
更新时间 2026-05-08 06:40:14 UTC
浏览: 2664   回复: 1
Notifications sur Android
Cyrille ROBINET
更新时间 2026-05-03 16:14:14 UTC
Bonjour,
J'aimerais avoir de l'aide.
Merci
浏览: 2723   回复: 1
