Whisperer 2 temperature?
Brett Rabe
更新时间 2025-05-09 19:07:46 UTC
Thoughts?
浏览: 8679   回复: 1
Will not connect
Rick VanHooser
更新时间 2025-05-10 16:15:01 UTC
浏览: 8345   回复: 2
Panda88
更新时间 2025-05-15 18:20:45 UTC
浏览: 8362   回复: 1
Paolo S
更新时间 2025-05-15 20:41:08 UTC
How can I do?
浏览: 8673   回复: 1
更新时间 2025-05-16 12:40:39 UTC
浏览: 9266   回复: 1
Whisper Gen 2 update firmware
Phil Middleton
更新时间 2025-05-16 14:28:46 UTC
浏览: 7408   回复: 1
Transformer replacement
zoompj@gmail.com
更新时间 2025-05-18 18:43:54 UTC
I have Netro 6
Please help
浏览: 9447   回复: 1
Minh Thu Nguyen
更新时间 2025-05-19 08:42:52 UTC
Dear Netro Support Team,
Best regards,
Minh Thu, Nguyen
浏览: 9358   回复: 1
Smart Zones are random
Dave H
更新时间 2025-05-19 15:27:46 UTC
Sprite-12
and/or
浏览: 8596   回复: 1
overwatering
更新时间 2025-05-20 12:55:43 UTC
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
浏览: 8752   回复: 2
Refurbished netro controller
drylake
更新时间 2025-05-23 23:37:47 UTC
浏览: 8146   回复: 1
Battery Issue - Netro Stream
K L
更新时间 2025-05-25 03:09:56 UTC
Dear Fellows,
Device Details:
  • Hardware : Netro Stream 1.0
  • Firmware: 1.0.0
Best regards,
Kelvin
浏览: 9082   回复: 1
Mikael Hammarin
更新时间 2025-05-26 17:18:52 UTC
Suggestion:
浏览: 8692   回复: 1
New Sprite Owner
Bryant Bustamante
更新时间 2025-05-26 22:46:01 UTC
浏览: 9155   回复: 1
How do I change schedule
George S
更新时间 2025-05-27 21:37:14 UTC
浏览: 7391   回复: 1
Whisperer 2 Dead
更新时间 2025-05-27 23:06:05 UTC
浏览: 9445   回复: 2
Water consumption
cwo
更新时间 2025-06-01 19:51:34 UTC
浏览: 7787   回复: 1
Alexa with two Pizie
Stefano Giorgi
更新时间 2025-06-03 16:11:11 UTC
How can I fix this issue?
浏览: 7395   回复: 1
Dropped wifi (2.4 Gz)
C Hill
更新时间 2025-06-06 02:10:45 UTC
浏览: 6143   回复: 1
Contrôler problem
Alain Turcotte
更新时间 2025-06-06 09:41:00 UTC
浏览: 7243   回复: 2
