Email address length
Alberto Castro Hinojosa
更新時間 2020-10-24 21:37:57 UTC
Could you review please?
瀏覽: 4599   回覆: 1
HomeOwner
Isaac Fishman
更新時間 2020-09-21 01:14:55 UTC
瀏覽: 4452   回覆: 1
controller kept go offline
更新時間 2020-09-05 01:12:13 UTC
Hello, wondering why my watering controller kept going offline.  Once turning it off/on, it will goes online again but will go off in several hours later.  Is it time for me to get a new controller?  I hope not
瀏覽: 5102   回覆: 2
Battery not charging
Petar Nedyalkov
更新時間 2020-08-21 18:24:41 UTC
My solar powered controller doesn’t charge its battery - not sure if it’s a battery problem - the controller is under direct sunlight for at least 6 hours every day.
I’ve set it to water for 1 hour every day so it’s a simple On/Off once a day.
Have other people had this issue?
瀏覽: 4988   回覆: 2
Unable to reset into Host mode to change WiFi setting
dabo
更新時間 2020-08-16 17:29:54 UTC
I have a 6 zone Netro sprite and need to update my wifi settings. No matter what I do I'm unable to get the Netro to enter host mode. I've tried hitting the RST button numerous times before or after manual reboots (even waiting the full 3+ minutes after re-plugging the device in). I even tried a full manual reset by holding the RST button for 10 seconds and the device still doesn't reset. I'm starting to doubt whether the reset button on my device works.
Has any one had any similar problems or pointers for just getting the Netro to join a new WiFi network? I'd rather not do a full reset and lose my zone settings, but at this point I've even tried that and can't get that working.
瀏覽: 4760   回覆: 2
No funciona
Fre Camp
更新時間 2020-08-13 07:40:48 UTC
En la APP todo parece ir bien, pero no riega.
瀏覽: 4645   回覆: 2
Battery not holding charge
Steve Walczak
更新時間 2020-08-12 17:49:20 UTC
瀏覽: 4636   回覆: 2
Skipped watering on calendar and the system still watered...
Daniel Schoonover
更新時間 2020-07-26 01:36:47 UTC
I noticed system was going to water this afternoon so I skied the watering on the calendar hours before.
When the time came the system still watered my yard?
Why?
And I could not find a single way to stop it.
瀏覽: 4659   回覆: 1
Netro Sprite dead after 27 months (3 months post-warranty)
Doug Burkott
更新時間 2020-07-17 11:26:34 UTC
Has anyone had an issue with their Sprite being inoperable shortly after the warranty ended?  I tested the power prongs with a voltmeter and the controller is getting electricity, but no lights are on.   It's 105 deg in Austin and no rain in sight.  I'm going out of town for 5 days, so I'm in trouble.  I'm going to have to go to Home Depot to get something off the shelf installed today before my trip.
Anyone with the same problem?  Has anyone been successful with a claim outside of the warranty period?
Update:  The Sprite went offline at the same time the LED light stopped working.  The watering schedule resumed two days later and the LED was still off.  Meaning - Sprite works fine, LED doesn't work.  Netro told me to send the unit in over the winter and they will repair the LED.  Awesome - thanks Netro!
All the best,
-Doug
瀏覽: 5013   回覆: 2
Offline sratusc
Andrea Del Ben
更新時間 2020-07-12 19:31:12 UTC
瀏覽: 4720   回覆: 1
JanT
更新時間 2020-07-08 18:44:04 UTC
瀏覽: 4589   回覆: 1
Jim Falvey
更新時間 2020-07-07 23:54:23 UTC
瀏覽: 4782   回覆: 1
low water pressure
vic sabo
更新時間 2020-07-02 22:08:39 UTC
瀏覽: 4670   回覆: 1
Power Cycle
Jorge Bastos
更新時間 2020-06-26 22:30:53 UTC
Any way to correct this?
Regards.
瀏覽: 4649   回覆: 1
Mark Poppen
更新時間 2020-06-12 01:34:57 UTC
瀏覽: 4838   回覆: 1
Watering program
Maciej Karpinski
更新時間 2020-05-18 01:01:57 UTC
瀏覽: 4906   回覆: 1
alnavasa
更新時間 2020-05-08 20:36:44 UTC
Start ar 21:00 end at 3am
瀏覽: 6032   評論: 0
I want to increase watering time since it only says 2:00 minutes (it works for this time) but am unable to increase/change it. Please help. Please help!
Anne Knudsen
更新時間 2020-05-03 16:47:04 UTC
I can not change the time (number of minutes) for watering to happen. please help.
Two of the zones are 45 minutes and 60 minutes and they work.
瀏覽: 4612   回覆: 1
Watering when zones are off
Ben Wojcik
更新時間 2020-05-02 13:07:30 UTC
I turned off all my zones, but my netro still stays is watering.  How do I get it to stop doing this?  I can't figure out what its watering either.
瀏覽: 5358   回覆: 1
Problem with controling relay
Srdjan
更新時間 2020-04-26 06:54:18 UTC
Hi, i try to control working water pump by M contact on controler using relay(24VAC) and that is not posible, I try with three different relays and same situation.
Is anybody have same or similary problem and if anybody use M contact for controling relay please send tehnical data or picture of that releay that I can buy same... Suporrt not answering on this question I send them video of working two different relays but not got answer...
I tru to upload video here but that is not posible...
Thank for help.
瀏覽: 4743   回覆: 1
