更新時間 2018-09-12 07:54:55 UTC
Resources:
瀏覽: 439518   評論: 95
Thresholds
Shady Trails
更新時間 2023-12-23 16:16:15 UTC
瀏覽: 4732   評論: 3
Junk box pixie
Ray Williams
更新時間 2021-06-17 22:30:16 UTC
So Dissatisfied
瀏覽: 6514   評論: 1
更新時間 2023-11-07 13:27:20 UTC
瀏覽: 37151   評論: 1
Good results
R C
更新時間 2023-10-24 18:55:29 UTC
瀏覽: 5921   評論: 2
Vincent Coutinho
更新時間 2023-02-18 16:26:02 UTC
瀏覽: 5389   評論: 2
Netro Plugin for Jeedom
更新時間 2022-11-30 22:07:13 UTC
Hello guys,
kcofoni
瀏覽: 5687   評論: 1
Kickstart the Netro Zigbee Hub and Pixie-Z1
更新時間 2022-09-13 06:23:11 UTC
To the Netro community:
We are excited to introduce our new products, the Netro Zigbee Hub and the new smart timer Pixie-Z1. They combined deliver a different experience of smart watering system.
The Netro Zigbee Hub hosts a long-range local Zigbee network that links all the end devices. It connects to your router (wireless or wired) to transfer data between the end devices and the Netro cloud service. The Hub will work with all our Zigbee products including the new timer Pixie-Z1(introduced below) and the new soil moisture sensor coming this year, as well as the new 4-Zone sprinkler controller and the new weather sensor coming next year.
The new host timer Pixie-Z1 is re-designed from the original Pixie timer in many ways:
1. Always online for instant quick runs. No more sleep mode
2. Powered by two AA alkaline batteries with approximately one year of battery life. Notifications on low battery
3. Supports Google Home and Google Assistant
The Netro Zigbee Hub and Pixie-Z1 are expected to ship in September. To join the Tester program please email to info@netrohome.com and we will send you a discount code in return for feedbacks.
瀏覽: 125105   評論: 3
Android devices logout issue
Wency Pan
更新時間 2022-07-12 06:35:45 UTC
瀏覽: 6153   評論: 1
Rain presiction is wrong
Paul X
更新時間 2022-07-04 15:12:41 UTC
瀏覽: 5906   評論: 1
Manual operation
Paola Pinnavaia
更新時間 2022-06-17 23:21:30 UTC
It is a serious problem
瀏覽: 75599   評論: 2
Ron
Ron Ferrars
更新時間 2022-05-30 14:12:27 UTC
瀏覽: 6167   評論: 1
Sleeping mode
Fabrice GOUFFRAN
更新時間 2022-05-18 10:11:40 UTC
瀏覽: 6158   評論: 1
Like the app update.
Dave Henderson
更新時間 2022-04-09 02:14:47 UTC
瀏覽: 66027   評論: 3
Lloyd Walter
更新時間 2022-03-23 08:31:18 UTC
瀏覽: 6723   評論: 3
Mi experiencia con Netro
Marcelo Vasquez
更新時間 2021-11-25 18:21:23 UTC
Hola les cuento mi experiencia con Netro, trabajo actualmente en el estado de Nueva York, y tengo 500 plantas de bluebery en Chile souh America, y lo controlo desde acá, he tenido excelentes resultados con el sensor de humedad, me hubiese gustado que el sensor fuera más largo, pero con el actual se ha manejado perfecto, también creo que deberían diseñar una caja más robusta para exteriores, estoy muy feliz con la aplicación con el equipo y el sensor.
瀏覽: 6537   評論: 2
Nuova interfaccia penosa!!
Andrea DiPi
更新時間 2021-11-05 03:00:01 UTC
瀏覽: 7181   評論: 1
更新時間 2021-10-07 05:53:59 UTC
Dear Netro users,
瀏覽: 6585   評論: 0
Netro and Home Assistant
Jens Wymeersch
更新時間 2021-07-28 18:18:16 UTC
瀏覽: 9317   評論: 7
Whisperer availability
更新時間 2025-03-16 18:50:01 UTC
瀏覽: 2508   評論: 1
