Can’t get water to work
Ally P
更新時間 2024-05-07 18:45:51 UTC
I moved into a house with the Sprite 6 system and have it fully set up on my phone, however can’t get the water to actually run. I haven’t touched anything. Any advice?
瀏覽: 4148   回覆: 1
How to remove rain delay
Gyanendra Kumar
更新時間 2022-08-18 19:35:45 UTC
瀏覽: 5539   回覆: 1
New Braunfels Utilities stage 3 restrictions
Elisha H
更新時間 2022-07-19 18:08:31 UTC
We currently are under stage 3 restrictions, every other week on certain days. Photo to follow showing our restrictions & the smart app restrictions.
瀏覽: 5358   回覆: 2
Netro Spark question
Robert Dambrosio
更新時間 2022-06-12 20:59:09 UTC
瀏覽: 5291   回覆: 2
更新時間 2022-05-23 14:33:07 UTC
瀏覽: 5414   回覆: 1
Gaspare Miceli
更新時間 2022-04-18 06:23:55 UTC
瀏覽: 5489   回覆: 1
UK watering restrictions
更新時間 2021-06-01 11:26:19 UTC
Cheers,
Andy
瀏覽: 6015   回覆: 1
Disable a zone
fernando colon
更新時間 2021-04-10 14:15:21 UTC
瀏覽: 5865   回覆: 1
更新時間 2019-12-25 01:46:02 UTC
To the Netro Community,
瀏覽: 8239   評論: 0
Location Based Watering Restrictions - Check-in Interval
Matt Grooms
更新時間 2019-07-14 18:58:52 UTC
One of the great features of Netro is it's ability to look up my local (city/state) watering regulations, and apply them to my watering schedule. Bravo Netro!
Months ago, when I installed my Netro controller it looked up the then current (Stage-One) restrictions, and applied them to my watering schedule. However, since that time the watering restrictions have been eased (Year-Round restrictions) , and I'm allowed to water any day of the week. Well, Netro did not follow the changes and is still applying the old restrictions.
I attempted to trick Netro into rereading my local restrictions by turning the feature off, then back on. No luck.
So the questions are:
1) How often does a Netro Controller check the cloud database for updated watering restriction for it's location?
2) How often does Netro Central (you guys) check with communities for watering restriction updates and update your database so that deployed Netro controllers get accurate rules to apply?
I can see where it might be hard to keep up with small communities and rural areas, but my location (San Antonio, Texas, USA) has almost two-million people in the area. A single update on your part would provide a potentially large number of Netro users with current watering restriction information.
Matt
瀏覽: 7981   回覆: 1
Netro + Netatmo
Luca Magnani
更新時間 2019-07-14 07:42:29 UTC
Good morning
I have a netatmo weather station,
it would be nice to connect it to read the weather data precisely for my area.
Thank you in advance
瀏覽: 8172   回覆: 1
Military time
Matty B
更新時間 2019-06-05 14:34:21 UTC
Can the time be changed on the schedule to AM/PM and not 24/hr clock?
AccuWeather.com if selected waters in the AM. If i switch it to the other 2 it changes the schedule to PM watering. What is the reasoning behind this? I would prefer AM watering but would like to use a different weather provider.
瀏覽: 7757   回覆: 1
更新時間 2018-06-04 10:03:46 UTC
References
瀏覽: 10011   評論: 0
