Nigel Briggs
更新時間 2025-01-15 10:05:07 UTC
Why ?
瀏覽: 3835   回覆: 1
Sensori funziona anomala
Mattia Forti
更新時間 2024-06-03 07:45:35 UTC
Ho un sensore che funziona male, non legge la temperatura e la lettura del umidità è un altalena.
Come posso risolvere? Inoltre rileva umidità 25% e sta piovendo abbondantemente da più di 2 ore.
瀏覽: 4992   回覆: 2
Pixie z1 - smart scheduling for vegetable garden
Jamie J
更新時間 2024-05-15 14:47:14 UTC
Hello!
We just planted a raised bed vegetable garden with a variety of fruits and vegetables (zucchini, yellow squash, cucumber, green beans, strawberries, 2x blueberry bushes) and I bought the Pixie Z1 to use with a soaker hose setup.
I just setup the pixie and discovered the smart watering options do not include any of these plants.
Does anyone have successful recommendations for settings that would be best for a vegetable garden?
瀏覽: 4126   回覆: 0
Recommend watering schedule
Carolyn Simmons
更新時間 2024-03-17 23:35:07 UTC
We are in zone 9 in Conroe, Texas and would love knowledge on best length of time to water and how often!  Recommendations please!
瀏覽: 4701   回覆: 1
Starting new garden from scratch
Cori
更新時間 2024-03-06 03:16:19 UTC
Hello!
Everything is setup to sow our 170m2 of grass this weekend.
All local gardeners told me to irriigate the planted seeds 5min during the morning and 5min during the night, everyday, however the Netro smart program sets up a weird combination of 10min at 6am then 10 min at 6:40am, and then also for instance 2 days off (each phase, we have 3 for the grass), and this is choosing 'new plant' option.
  Should we leave the Netro smart program or Should we choose our own one???
Thanks!!
瀏覽: 4611   回覆: 1
Good results
R C
更新時間 2023-10-24 18:55:29 UTC
瀏覽: 5921   評論: 2
Luis T
更新時間 2023-06-18 15:30:17 UTC
Any comments are welcome.
瀏覽: 5430   回覆: 3
S R
更新時間 2023-05-13 00:02:22 UTC
瀏覽: 6048   回覆: 2
Intelligent mode useless
Juan Lambea
更新時間 2023-04-14 15:51:37 UTC
瀏覽: 5134   回覆: 1
carlos davalos melgar
更新時間 2023-04-13 20:07:05 UTC
瀏覽: 4782   回覆: 1
更新時間 2023-04-13 20:06:57 UTC
瀏覽: 4833   回覆: 0
Alessandro Alfei
更新時間 2022-11-11 23:11:30 UTC
Ciao, una domanda.
瀏覽: 5685   回覆: 1
Soil
Stephen Brewer
更新時間 2022-08-27 12:11:15 UTC
Many thanks in advance
瀏覽: 5518   回覆: 1
Jorge Izquierdo
更新時間 2022-08-11 10:31:39 UTC
Regards!
瀏覽: 5337   回覆: 1
Rocky Hill
更新時間 2021-07-05 12:35:21 UTC
  • Tomatoes;
瀏覽: 8014   回覆: 2
BOB COOPER
更新時間 2021-06-20 16:40:50 UTC
瀏覽: 6076   回覆: 1
Abel Vargas
更新時間 2021-04-09 00:49:42 UTC
瀏覽: 6200   回覆: 1
Ideal Soil Moisture
Mike Biondo
更新時間 2021-03-26 01:51:09 UTC
What is an ideal soil moisture level? My new Netro Whisper is measuring 83% down from 88% 3 hours ago. Is this too moist? It is average raised bed plant soil. I have googled and found some sites saying no more than 45% and some sites say no less than 70% so I am very confused!
瀏覽: 6289   回覆: 1
Moisture and light range
Don Lewandowski
更新時間 2020-12-31 21:46:19 UTC
瀏覽: 6072   回覆: 1
Moisture uncorrect
Andrea Pieri
更新時間 2020-12-08 05:43:25 UTC
瀏覽: 6086   回覆: 1
