Moisture level for lawn
Jan
更新時間 2020-08-08 08:43:43 UTC
Dear community
瀏覽: 5962   回覆: 1
Metrosideros (Myrtaceae)
Alessandro Raffi
更新時間 2020-06-03 21:09:16 UTC
Thanks a lot,
Ale
瀏覽: 6954   回覆: 1
Max V
更新時間 2020-03-27 18:52:10 UTC
Hi everyone!
瀏覽: 6713   回覆: 1
Garden
Steven Carnie
更新時間 2020-03-26 14:53:02 UTC
瀏覽: 6961   回覆: 1
Riego netro para tepes
Manuel C
更新時間 2019-10-23 09:36:27 UTC
Hola,
瀏覽: 6810   回覆: 1
morriewayne17@yahoo.com
Morrie Wayne
更新時間 2019-06-14 13:27:19 UTC
瀏覽: 6955   回覆: 0
St. Augustine
Spencer Vaughn
更新時間 2019-01-10 03:15:53 UTC
瀏覽: 7211   回覆: 2
更新時間 2018-12-13 07:48:53 UTC
Burning Bush
Fragrant Sumac
Japanese Yew
California Lilac
Creeping Juniper
Dwarf Forsythia
Snowberry
Siberian
Carpet Cypress
瀏覽: 8779   評論: 1
更新時間 2018-09-12 07:54:55 UTC
Resources:
瀏覽: 439562   評論: 95
What percentage is ideal for the moisture content for a summer lawn in Southern CA?
Gary Riehl
更新時間 2018-08-17 18:05:53 UTC
Can you please tell me the ideal percentage for the top soil and sub soil for a Southern CA. lawn in summer?  Does this number change during the other seasons?
Gary
瀏覽: 7157   回覆: 0
Soil type?
John Broadbent
更新時間 2018-06-16 14:27:36 UTC
瀏覽: 8055   回覆: 2
更新時間 2018-06-04 12:37:29 UTC
1.Year One
3.After the first week or so
4.Years Two to Three
5.After Year Three
Helpful Tips
Before you water:
瀏覽: 10490   評論: 4
How to Water Trees and Shrubs
更新時間 2018-06-04 10:07:08 UTC
1.How to Water Shrubs
2.How to Water Trees
Don't wait for the plants to tell you with wilting and leaves dropping off. Then youll just be watering to keep the plants roots alive so it may possible come back later. Inspect the soil. Dig around with your hands, soil probe, garden trowel, or shovel. Youll be able to tell quickly how far down you are actually watering.
Resources
瀏覽: 10441   評論: 3
