更新時間 2025-08-10 00:01:57 UTC
瀏覽: 381   回覆: 1
Watering time
Andrew Gor
更新時間 2025-07-23 14:36:45 UTC
I added the Netro whisperer 2 soil sensor to my ficus pot. The sensor gives me contradictory messages. It says that next watering should be in one week but every night it sends a notification to 'water the ficus sensor's. What should I do?
瀏覽: 1100   回覆: 1
更新時間 2025-07-10 18:58:03 UTC
Kirk
瀏覽: 1110   回覆: 1
WEATHER CONDITIONS - Rain
Zsolt Karman
更新時間 2025-07-08 10:23:15 UTC
Hi Team,
Could you please ?
Controller SN: 0cb815314670
Regards, Zsolt
瀏覽: 1568   回覆: 1
更新時間 2025-06-25 16:41:56 UTC
瀏覽: 1143   回覆: 1
Time range not respected
Fabio Silvestri
更新時間 2025-06-19 16:29:56 UTC
瀏覽: 1215   回覆: 1
Ciccio Pasticcio
更新時間 2025-06-09 06:53:42 UTC
瀏覽: 1510   回覆: 1
overwatering
更新時間 2025-05-20 12:55:43 UTC
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
瀏覽: 2282   回覆: 2
Smart Zones are random
Dave H
更新時間 2025-05-19 15:27:46 UTC
Sprite-12
and/or
瀏覽: 2267   回覆: 1
Panda88
更新時間 2025-05-15 18:20:45 UTC
瀏覽: 2229   回覆: 1
Whisperer 2
Stephen Brewer
更新時間 2025-04-24 13:43:01 UTC
Steve
瀏覽: 2239   回覆: 1
Matt
更新時間 2025-04-08 16:25:11 UTC
瀏覽: 2306   回覆: 1
Discount
darla
更新時間 2025-01-30 20:05:17 UTC
Darla Carpenter
瀏覽: 2927   回覆: 1
Netro offline
Brett Gardner
更新時間 2025-01-20 00:02:43 UTC
Suggestions?
Hard reset?
Brett
瀏覽: 3059   回覆: 1
Fat Cut
更新時間 2024-12-29 07:11:04 UTC
瀏覽: 3224   回覆: 1
Zine will not run
TJ Woods
更新時間 2024-10-27 14:40:45 UTC
瀏覽: 3569   回覆: 1
1 zone not watering
cowlo@xtra.co.nz
更新時間 2024-10-01 01:41:13 UTC
瀏覽: 3621   回覆: 1
Pierluigi Cilli
更新時間 2024-09-08 07:29:59 UTC
瀏覽: 3651   回覆: 1
Can't get desired watering time
Fabio Silvestri
更新時間 2024-07-24 19:24:30 UTC
I'm struggling to setup watering time, even after third season im using this app.
As per my settings, EPA suggest to water every day, 30 minutes a day for each zone. The grass is getting sick as all past 2 years, cause the frequency is too high.
I would expect it to water for 1 hour, each 3-4 days. This is what i call "deep watering".
I tried following settings, the frequency decreases, but no way that i can increase the watering time which remains 30 minutes.
Help please
瀏覽: 3927   回覆: 1
Connection
jackielaith
更新時間 2024-07-21 04:36:32 UTC
Can't connect to the internet with this app
瀏覽: 3904   回覆: 1
