Insufficient watering
Gianluca Vettore
更新時間 2022-06-11 18:29:36 UTC
Thanks for your help.
瀏覽: 3887   回覆: 2
Rain restriction
Geron R
更新時間 2022-06-11 11:38:54 UTC
瀏覽: 4183   回覆: 1
Ron
Ron Ferrars
更新時間 2022-05-30 14:12:27 UTC
瀏覽: 6177   評論: 1
milanese
更新時間 2022-05-27 02:32:57 UTC
iPhone -
- Get app
- Crete account
- Go to connect timer
- Next
- Enter name and stuff, next
- Turn on unit, next
Please advise.
瀏覽: 3968   回覆: 1
Bayoule Bayoule
更新時間 2022-05-24 18:50:51 UTC
JM
瀏覽: 3989   回覆: 2
Broken part
Jeremie Coderre
更新時間 2022-05-10 02:52:42 UTC
Hi there!
Thanks in advance!
瀏覽: 3952   回覆: 1
Rain Strategy
Luca Cerini
更新時間 2022-05-09 09:24:20 UTC
Luca
瀏覽: 3847   回覆: 1
Watering out of schedule time
Luca Cerini
更新時間 2022-05-09 09:14:09 UTC
Luca
瀏覽: 3804   回覆: 1
No moisture reading
dsingelyn
更新時間 2022-05-04 17:59:14 UTC
Suggestions?
瀏覽: 4315   回覆: 3
Rain stop
Javier Baruque
更新時間 2022-05-03 14:52:20 UTC
瀏覽: 3859   回覆: 1
Whisper Sensor
Ian Moore
更新時間 2022-04-26 02:55:10 UTC
瀏覽: 4184   回覆: 1
更新時間 2022-04-24 01:45:07 UTC
瀏覽: 9366   評論: 1
doppia irrigazione
mauro croce
更新時間 2022-04-22 10:52:27 UTC
瀏覽: 4176   回覆: 1
John Lillistone
更新時間 2022-04-19 11:26:49 UTC
瀏覽: 3865   回覆: 1
Dsohunter
更新時間 2022-04-13 14:39:27 UTC
瀏覽: 4125   回覆: 2
Parts for Pixie
Robert Squires
更新時間 2022-04-11 14:11:50 UTC
瀏覽: 4011   回覆: 2
Flow rate
Sander Z
更新時間 2022-03-14 12:34:05 UTC
瀏覽: 4028   回覆: 1
Netro is watering at 25F because it is misinterpreted weather
Ben Aggus
更新時間 2022-01-11 12:15:06 UTC
I had to cancel watering because it’s 25F this morning. It’s because the weather is misinterpreted. The forecast today is 58/34, but that means it will be 34 for tonight’s low. Last night’s low was 25 and the Netro should look at that number for watering this morning.
瀏覽: 4449   回覆: 1
Weather not updating
Mick Faulks
更新時間 2022-01-05 00:20:42 UTC
NetroWeather not updating, other weather apps only update if they are resubmitted every couple of days, is it possible to add other weather providers to the app?
瀏覽: 4415   回覆: 2
arubalsky
更新時間 2021-12-01 13:44:22 UTC
Example:
Pixie 1 - Nov 24 - Good run
Pixie 2 - Nov 24 - Good run
Pixie 2 - Nov 26 - Good run
Pixie 1 - Nov 28 - Good run
Pixie 2 - Nov 28 - Good run
Pixie 2 - Nov 30 - Good run
瀏覽: 4257   回覆: 1
