Lost connection on holidays
lekter
更新時間 2020-08-12 08:45:08 UTC
I'm on vacation and my internet connection has been cut off. I had planned before on netro waterings for the week. Is that without an internet connection in my house, the waterings programmed before will still be done?
Arnaud
瀏覽: 4549   回覆: 2
Smart watering
Alejandro Foubelo
更新時間 2020-08-07 01:27:29 UTC
Hello, I set the app to run 3 manual programs on the odds day and I have the smart watering system active on all zones.
Will it skip my watering if there is rain in the forecast on an odd day?
瀏覽: 4391   回覆: 1
Confused about schedule
Bowie Xu
更新時間 2020-08-04 18:52:19 UTC
I am a new user here and just installed the Netro in my house. The “Smart watering” schedule seems very odd to me.
As you can see there are 2 rounds for each zone and the time of zone 4 is about an hour in one round. Is this normal ?
Bowie
瀏覽: 4782   回覆: 1
Watering "off the books"
wwhitfill
更新時間 2020-08-02 23:26:54 UTC
Right now the watering schedule the Netro program is using for my St. Augustine grass is killing my grass. I live in Dallas and Jully/August is brutal on lawns. If I water outside the schedule the program has established the schedule is changed. Is there anyway for me to water my with Netro and keep the smart watering schedule Netro has? Right now I by pass the Netro by manually engaging my water values, not using Netro.
Will
瀏覽: 4430   回覆: 1
Water turned off
Ken Laberteaux
更新時間 2020-07-31 01:08:39 UTC
I had to turn off my water valve to my sprinkler system for a week (ending in a few days) and forgot to disable smart watering on my netro.  Netro thinks it did a complete watering last Saturday, and adjusted estimated soil moisture accordingly.  Netro isn't planning another watering for another 9-10 days.  However no watering last Saturday occurred.
How best should I handle this?  Is there a way to delete past watering, which will lower soil estimated moisture, triggering a sooner watering than currently scheduled?  Or should I just do a manual long watering as soon as I can?
瀏覽: 4627   回覆: 1
更新時間 2020-07-28 05:32:10 UTC
I have an issue/conflict  with the watering adjustments for the sensors and the Smart Zone Sheduling
I have seen something weird.
  • I Have set up the Watering Adjustment for sensors the following I describe o be sure about the problem
  • Moisture to Skip watering 50%
  • Moisture to Add watering 30%
  • Duration 5 minutes (only) -- it is a check
  • The Smart Zones are st up the following
  • Smart Zone - enabled
  • Mode - regular
The watering run today only 5 minutes, when the smart  schedule  defined by the system was above that. As you can see, tomorrow watering says different time runs per zone, but it will run a maximum of 5 minutes. This means that the sensor configuration overrides the Smart Zone. And it should not.
As far as I understand the Watering adjustemt is to add EXTRA watering when needed based on the moisture level. Attached picture
Prior to this setup I had the Duration for Watering Adjustment for 15  and 10 minutes, and you can see in the past days runs, that always run for 15 -10 minutes depending the zone/sensor. - Attached picture
In previous weeks, it was working fine and adding extra watering when need it to keep the moisture levels.
Any idea?
I DID THE CHANGES PROPOSED BY NETRO  and it is not working
Take a look the screen shots
Zones 3,4,5 it is below the 30% trigger
瀏覽: 4958   回覆: 1
I'm not understanding how "estimated frequency and duration" works...
Izio Sem
更新時間 2020-07-18 07:24:18 UTC
Ciao.
Just installed Netro Sprite.
I enjoyed to set up the zones with advanced Smart watering, but I'm not confident with what is reported in "estimated frequency and duration". The frequency showed in the setting page seems too long (e.g. every 6 days)... but, if I see what is scheduled in the calendar it seems much closer to my expectation (e.g. every 2 days).   How daoes it work??
Maurizio
瀏覽: 4698   回覆: 1
Does Netro whisperer underestimate moisture?
Rick Agrawal
更新時間 2020-07-16 19:12:17 UTC
I added a whisperer to one of our zones. Recently the moisture content was between 25-30%. We are having a hot summer with many days with 110 degrees. I believed it and watered for good 15-20 minutes. It turned out despite all those water the soil moisture went up to 45-50%. I went and checked again, the soil looks pretty good and appeared moist.
Just curious if the whisperer tends to underestimate moisture?
瀏覽: 4420   回覆: 1
Watering Frequency
Andrei Stancovici
更新時間 2020-07-16 05:36:44 UTC
Hello.
I installed my netro yesterday and now after watering all zones it shows me that the next watering will be in 5 days. It seems to be to far away in the future since it's 35 degrees celsius and sunny all day
瀏覽: 4279   回覆: 1
Smart watering issue?
Ananth
更新時間 2020-07-15 13:14:40 UTC
瀏覽: 4537   回覆: 1
user manual in spanish
Alejandro
更新時間 2020-07-14 10:00:20 UTC
瀏覽: 4539   回覆: 1
Not enough watering time
Homestead One
更新時間 2020-07-08 20:04:00 UTC
I have 4 zones activated.
Please help.
瀏覽: 4638   回覆: 1
Arthur
更新時間 2020-07-08 16:08:19 UTC
瀏覽: 4269   回覆: 1
Hozelock
Alan George
更新時間 2020-07-06 18:50:08 UTC
瀏覽: 4363   回覆: 1
sw238
更新時間 2020-07-05 15:42:38 UTC
瀏覽: 4358   回覆: 1
Michael Fortwengler
更新時間 2020-07-04 19:06:14 UTC
瀏覽: 4309   回覆: 1
Rob and Susan Tartre
更新時間 2020-06-24 20:13:25 UTC
Thank you for any help!!
瀏覽: 5080   回覆: 3
Certificate Expired?
Robohead
更新時間 2020-06-19 20:03:10 UTC
瀏覽: 4611   回覆: 2
Andy Black
更新時間 2020-06-15 21:10:38 UTC
Andy
瀏覽: 4216   回覆: 1
更新時間 2020-06-14 12:28:36 UTC
瀏覽: 4711   回覆: 1
