Smart water regulation
Albert Heinold
更新時間 2021-05-13 09:40:49 UTC
Thanks for any help.
瀏覽: 3877   回覆: 1
Whisperer stop working
Gianluca De Virgilio
更新時間 2021-05-11 15:34:15 UTC
Ideas?
瀏覽: 4212   回覆: 1
One of my zones isn't smart watering
Mitch Green
更新時間 2021-05-02 12:39:44 UTC
2 of my 3 zones are automatically watering however one zone is not any thoughts why?
瀏覽: 4340   回覆: 1
To many watering with smart option
Adrian Nagy
更新時間 2021-05-02 06:10:18 UTC
Dear Netro,
I jut set up your device (again; because it is spring here); but smart watering time look way to much. Why do I need to water my 100 Sqm grass 5 times 8min in a day?
Thank you for your help in advance , Adrián
瀏覽: 4087   回覆: 2
Adjusting watering amount to match restrictions
Trevor M
更新時間 2021-05-01 11:37:20 UTC
My region is currently asking that we only water once per week. I was under the impression that the smart controller made those adjustments automatically for me, but it is showing that I am scheduled to water 3x this week. Is the only way for me to change this to do it manually?
瀏覽: 4404   回覆: 2
Mitch Green
更新時間 2021-04-20 00:44:59 UTC
瀏覽: 4576   回覆: 1
How to Set Schedule?
tonycurry
更新時間 2021-04-14 02:13:12 UTC
瀏覽: 4136   回覆: 1
Instant watering
hermanins@gmail.com
更新時間 2021-04-03 00:01:28 UTC
瀏覽: 3959   回覆: 1
更新時間 2021-03-29 08:57:05 UTC
I have checked in the smart schedule that tomorrow is programmed to run zones that should be skipped.
I have set up the whisperer to skip run if moisture is above 40%. Current moisture is:
  • Zone 2 - 92%
  • Zone 5 - 70%
瀏覽: 4595   回覆: 2
Netro pixie Internet off
Andrea Zorgniotti
更新時間 2021-03-14 07:08:00 UTC
Hi, I'm the owner of a Netro 6 channel at my primary home where I use the smart watering function with no program, after 4 years I found the correct configuration and I'm really happy about the complete automation. In my vacancy home I bought a Pixie few weeks ago. I'm afraid the connection could be off when I'm not there. In the last weeks I set a program with 1 day on 5 min and the next off and the smart watering to check the rain and cancel the day raining. I would like to use the Pixie in the complete automation like in my principal home. So my question is what happen if I set only smart watering and then internet go off? Is it scheduled inside the Pixie a sort of program of watering that works anyway and the plant will receive water (even if in not an optimized way)?
瀏覽: 4350   回覆: 1
Skip watering moisture for Bermuda lawn
Fran Roman
更新時間 2021-03-09 20:30:13 UTC
Hi! I just installed my brand new whisperer, and I’m wondering which value I should configure for the skip watering functionality (80% by default). I have the perception that is too high for a Bermuda lawn.
瀏覽: 3977   回覆: 1
Sensor Temperature Reporting
Nasser Ahmed
更新時間 2020-12-14 02:12:42 UTC
One of my sensors is reporting strange temperature numbers. Any ideas on how to fix this. I tried a reboot and a reset (remove and add again).
瀏覽: 4292   回覆: 1
Automatic switch to 12 hour reporting for sensors
Julian Hansen
更新時間 2020-12-10 12:30:21 UTC
Hi I have 6 senors that have all worked perfectly for 3 months unattended. A month ago I noticed 1of them only had 5% charge so I switched it to 12 hour reporting and it is now on 38%. Today another sensor has gone to 0% charge and stopped reporting. It would be great if you could be set it automatically switch at say 30% charge. It will be 3 months before I am back to the house so I hope the sensor can recover. Thanks for a fantastic product.
瀏覽: 4562   回覆: 1
Stefan Pena
更新時間 2020-10-25 10:41:41 UTC
Hey guys!
瀏覽: 4166   回覆: 1
Manually entering rainfall
Curt Lizzi
更新時間 2020-10-17 13:16:09 UTC
瀏覽: 4447   回覆: 1
Multiple sprinklers in one zone - and is there a Test System ?
Cormac Champion
更新時間 2020-09-19 13:48:55 UTC
Can zones be setup with several sprinklers in the one zone ?  From what I can see from another question, is it correct that you setup the aproximate size of each zone ?  I have several zones with maybe 10 sprinklers in each zone, with sprinklers about 3m apart.
Also, is there any access to a test / simulation system that I can setup my location and see how well it would adapt to weather.  I am planning the installation for southern Spain
Thanks in advance
瀏覽: 4522   回覆: 1
Potted plant on terrace
Andrea Zorgniotti
更新時間 2020-09-14 07:46:03 UTC
Hi I Have a big terrace with many plants divided in 3 zone controlled by Netro. To use the smart watering and have an acceptable time/frequence for watering (6 min every 2.5 days) I have to set user and from 80% to 85% umidity. If I set frequent or extra water the estimated frequency is 4/5 days. Considering in summer my setting seems nor giving enough water to plants what kind of setting do you suggest to increase the frequency (change msq, kind of sprinkle or whatever).
Thanks in advance for answer
瀏覽: 4475   回覆: 1
Way to add weather stations
Curt Lizzi
更新時間 2020-09-12 01:16:55 UTC
I find the Weather apps to be very inaccurate with respect to rainfall at my home. Is there a way to add a near by weather station for better accuracy?
瀏覽: 4474   回覆: 1
Sensor watering adjustment doesn't work - bug
Roman Stanek
更新時間 2020-09-04 04:49:34 UTC
I installed two sensors today and added watering adjustment so that every time the humidity goes below 10% another 10 minutes of watering is added. Unfortunately, there is a bug and the watering time is triggered right away even though the faucet timer connects only every three hours. The additional watering time needs to be scheduled after the next timer sync and not right away. It's a clear bug.
瀏覽: 4354   回覆: 1
Keeps watering even though it rains
Oleg Frayman
更新時間 2020-09-02 01:51:56 UTC
My sprinklers keep watering even though skipping if it rains is selected with low threshhold
瀏覽: 4128   回覆: 1
